46RH trans fluid getting to hot.
Old Apr 4, 2026 | 02:30 PM
sdkauota's Avatar
sdkauota
Default 46RH trans fluid getting to hot.
Is there a way to keep the trans fluid from getting too hot when towing? It already has an external trans cooler and there is no option to upgrade the radiator. It's a 94 dodge ram 2500 with a 5.9L 8cyl gas.
Thanks!
Old Apr 4, 2026 | 03:06 PM
Don't tow in Overdrive......
Old Apr 4, 2026 | 03:58 PM
sdkauota's Avatar
sdkauota
Never tow in OD aways off when towing. It's the steep hills that really cause the temp to go up.
Old Apr 4, 2026 | 07:55 PM
What gears in the axles? What size tires?
Old Apr 5, 2026 | 09:18 AM
sdkauota's Avatar
sdkauota
Tire size is 245/ 75R 16 the gear ratio 3.55
Old Apr 5, 2026 | 10:02 AM
How much weight are you pulling?
I might be tempted to back flush the trans coolers..... With the radiator, and the aux cooler, your trans should not be overheating.
Old Apr 5, 2026 | 01:41 PM
sdkauota's Avatar
sdkauota
The dry weight trailer is 5k, I'm thinking with the truck and trailer loaded I'm pulling close to 7k.
Old Apr 5, 2026 | 03:07 PM
With a 2500, that shouldn't be problem.....
