rear end and 4:56 gears ?
Old Jan 18, 2006 | 04:50 PM
20dodgeram01's Avatar
20dodgeram01
Default rear end and 4:56 gears ?
hey.. i have a 2001 1500 with the 5.2.. 4x4.. i was wondering what my gear ratio is now.. and what kind of rear end i have.. im guessing a dana 60?? im looking into buying 4:56 gears soon so this is stuff i gotta know.. also.. do you guys know of any websites that have 4:56 gears? probally for a reasonable price..
Old Jan 18, 2006 | 04:55 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: rear end and 4:56 gears ?
Since it is a 4x4, you will need gears for both front and rear. Since it is a 1500, you rear end is a Chrysler 9.25. The front is a Dana 44. Stock gear ratio is 3.55, unless you have an Off-Road edition, in which case it could be 3.92 or 4.10.
A really good place for gears is Randy's Ring and Pinion. http://www.ringpinion.com/
Old Jan 18, 2006 | 07:36 PM
dodge_boy31807's Avatar
dodge_boy31807
Well i hate to say it but I think my rearend is goin out, when i am in 3rd gear at 35 mph and shift to 4th, it starts humming, and my buddies truck does the same thing and his finally went out today(we think it is the rearend). If I go looking for gears and the stuff I need, what exactly is it that I need? Its 318,95,1500, and 2wd
Old Jan 18, 2006 | 08:21 PM
Socha_62's Avatar
Socha_62
Just to clearify 3.92 is an option on non Off-Road models too Call the dealer and give them your VIN, just tell them you want to know what your gear ratio is, they'll be able to tell you.
dodge_boy31807: since you have a 4x2 you only obviously need gears for the back. Same axle, Chrysler 9.25. If its humming its probably the bearings, so if your gonna do gears make sure to get the Master Install Kit. Comes with new seals, bearings, and everything you need. Even if your keeping your current gears you just need the Master Install Kit to replace the bearings and seals
http://www.drivetraindepot.com/ is a pretty good site also
Old Jan 18, 2006 | 09:19 PM
Tani1500's Avatar
Tani1500
ok if your going to get gears. dont buy genuine gear. they suck. get yukons or richmond gear. also unless your running 35s or 38 in tires. your going to be way over geared.
Old Jan 18, 2006 | 09:23 PM
bigandbeutiful's Avatar
bigandbeutiful
some places have the packages were u can get both the front and rear gears for a better price
20dodgeram01
i plan on keeping my 3 inch Rough Country lift on and getting new wheels and 35's.. so would 4:56's be perfect? it has 33's on it now with 3:55's.. feels like its really under-geared.. kinda sluggish off the line
Old Jan 18, 2006 | 09:30 PM
Silver_Dodge
ORIGINAL: Tani1500
When I bought my gears, Randy's told me Yukon does not make a gear set for the Chrylser 9.25. You get a Motive or Sierra gear for the rear and a Yukon for the front Dana 44 if you order from Randy's.
Old Jan 18, 2006 | 09:47 PM
Tani1500's Avatar
Tani1500
oh yea. i got a richmond back there.
Old Jan 19, 2006 | 05:57 PM
Socha_62's Avatar
Socha_62
4.56's might be a bit much for 35's. 4.10's would probably be a better choice.
