straight cat?
hey i was gonna redo my exhaust and get a flowmaster but i decided i want it even louder so i think im going to just go straight cat my truck has a 5.9 liter engine. does anyone have a 5.9 running straight cat i wanna know if it sounds good or if its like insanly loud i want it reallly loud but i dont want it to sound bad. also do you loose power from it?
thanks
-craig
thanks
-craig
It will be insanely loud. I used to run my Ramcharger (318) straight off the Y-pipe, and you could hardly think...let alone listen to the radio. Not to mention the fact that depending on where you live, you'll most likely get a fine for noise violation.
And then there's not passing inspection because you don't have a muffler.
straight out the y pipe? wouldnt that be straightheaders? i dunno i want it to ****ing rumble the ground haha i know it will but will it sound good do you think? i think i might just go for it have some fun **** peole off set off car alarms have fun haha i dont really care about the ticket. is it true that if you pay the fine once you dont have to pay again or take it off?
Nah, the y-pipe went back pretty far on that truck.
And as far as the ticket, usually you get it fixed or pay the fine. And if you don't get it fixed and just pay...you could drive down the street and get another one for the exact same thing. Something like that, you'd best just fix it (or not do it in the first place). Besides, since you're in Cali, I'm almost positive you wouldn't pass inspection without a muffler.
Do NOT straight pipe it. I did for a while and I will never again.
1. Loud as hell yes, but it cracks like a mother when you let off the gas. It is loud, but it sounds like ****...
2. If screws your power. I went from stock, to straight pipe and noticed a LOSS in power. Put on my MagnaFlow and now I have alot my power.
3. Kiss your low end torque and gas milage goodbye. The engine needs back pressure for torque and gas milage. Straight piped it flows TOO much and you loose that back pressure.
Don't do it!
Don't do it!
What about just gutting the cat and having a flowmaster 40 series?
I currently have a flowmaster 40 series with dual out, I was thinking about gutting the CAT, how would that sound, is it good or bad, better MPG, more power?????
thanks guys
thanks guys
ORIGINAL: Funny Man
thanks guys
thanks guys
As far as gutting the cat, why not just pull it out and put a straight pipe in? Why waste a perfectly good converter? [>:] The throttle should be a little more responsive with it gone. Won't see any better MPG though. You'll also most likely need an 02 sensor eliminator...whether you pull the cat out or just gut it.
Trending Topics
I was gonna say, BlueMXblaster was not talking striaght exhuast, he was talking about taking the cat off or gutting it out and putting a Flowmaster 40 series on.
Now with the correct question, yes will be louder, but not extreme. I have the cat still on mine but no muffler and stright out the back of the truck, not extremely loud, but nice rumble. Only issue I would worry about is if it would mess up your O2 sensor reading or not?
As for can they give you more then one ticket for the same offence, in the same night no(unless it is speeding or careless driving), but for actuall non driver offences no they cant. Can they do it the next time they catch you, damn skippy they can, they can give you 1 a day for the rest of your life or till you fix what ever the issue is. Also, keep in account, that if you have Smog tests where you live it will mess that up also. Plus by most state laws, when you sell a vehicle, you have to make sure it will pass smog or have at least the smog equipment on it. Just food for thought. Good luck
ORIGINAL: livinginh
I have a 98 ram 1500 the cat was gutted before i got it and now the check engine light comes on cause of the 02 sensor where can i find the eliminator ?
