Rear end problems
Old Jan 19, 2006 | 01:54 AM
dodge_boy31807's Avatar
dodge_boy31807
Default Rear end problems
Just fixed the transmission and now this. While driving down the road at maybe 40 mph in 3rd gear going to 4th I hear this noise. It whines and a buddy of mines 94 ram did the same and it finally locked up on him today. *** end broke lose and threw him in the ditch, he wasn't heart but I don't want this to happen to me. Does anyone know what could be going out and what I need to look for to replace, I don't even know what kind of rear end it is. Im in the dark on this one guys.
Old Jan 19, 2006 | 02:48 PM
dodge_boy31807
Default RE: Rear end problems
Come on someone has to have replaced a rear end before. It doesn't seem that hard and someone on this forum has had to have had this noise before and fixed it. I just need me some help.
Old Jan 19, 2006 | 04:44 PM
94Champ's Avatar
94Champ
If your truck is a 1500 series you have a 9.25 rear end. Do a search of this forum as myself and others have described how to inspect it for problems.If you have a ring/pinion gear problem or ring/pinion gear bearing problem you should just take it to a reputable shop to have it fixed. Make sure it's not your tranny to since it sounds like it was just worked on.
Old Jan 20, 2006 | 01:18 AM
dodge_boy31807
Well about 5 months ago when the transmission first went out, I heard this noise but didn't know what it was but had a clue because this same noise I had he did and it was the rear end. Off the top of your head can you tell me what a 5 speed transmission take, gear oil wise.
Old Jan 21, 2006 | 02:46 AM
cableguy's Avatar
cableguy
Sounds like bearings in the rear. Mine made a howling noise for months. Since I bought it actually. I thought it was the tires. Ended up getting it fixed under warranty. Now that noise is gone but I thinkthe tranny is starting to go. Oh well.
Old Jan 21, 2006 | 04:20 AM
dodge_boy31807
Well that is what my buddy had told me and that is what I had figured was wrong but could it be the ring and pinion gear as well?
Old Jan 21, 2006 | 09:07 PM
Socha_62's Avatar
Socha_62
I doubt the ring and pinion is going to howl. I'd have to agree and say its your bearings. I'm sure you can buy just the bearings or you can get a Master Install Kit and replace all the seals, bearings, ect. They run you about $100. http://www.drivetraindepot.com
Old Jan 21, 2006 | 10:20 PM
kossuth's Avatar
kossuth
ORIGINAL: Socha_62
Actually the ring and pinion are more likely to cause a howl in the rearend than anything else in the rearend. The howl would come from eithor improperly setup gears or gears that are wearing weird. A weird wear could be from a messed up crush sleeve.
Old Jan 22, 2006 | 03:43 AM
Socha_62's Avatar
Socha_62
They wear pretty quickly, so if it was wear you'd think it would stop kinda quickly. But that would screw up your ring and pinion pretty good. [&:] Take your cover and look for grooves or wierd marks on your ring. Also look for metal shavings.
Don't forget the friction addative if you have a LSD!
