OD bucking
Old Jan 20, 2006 | 04:44 PM
Socha_62's Avatar
Socha_62
Default OD bucking
Well when in OD and driving anywhere from when it kicks in (35ish) to about 55 I get a nasty little buck. Its not very strong, pretty suttle, almost feels like I'm missfiring or hitting a small bump in the road, but I'm not. Only happens in OD between those speeds.
So, is this a rebuild in my future... ? I want to get a TransGo kit but I don't want to put it in just to have the trans break a week later. But if I get a shift kit and have to have it rebuild, can the kit be reused or is it shot after a rebuild?
Fresh fluid and filter within last 2k miles or so.
Old Jan 21, 2006 | 02:21 AM
cableguy's Avatar
cableguy
Default RE: OD bucking
Dude, my truck does the exact same thing. Right around 1900 rpm. If I stand on it and get it out of O/D, it runs fine. Suggestions, anyone??
Old Jan 21, 2006 | 03:31 AM
mattyge's Avatar
mattyge
not that this is any help to you but you're not alone, mine does the same thing, mostly when downshifting from overdrive to go up a hill or somthing. I just live with it, sorry i can't be of any help.
Old Jan 21, 2006 | 04:15 AM
20dodgeram01's Avatar
20dodgeram01
maybe they shift into overdrive at to low of a rpm to where it makes it buck alittle bit? i have a manual and if you shift into the next gear to soon it'll buck alittle till you get up to speed.
Old Jan 21, 2006 | 04:20 PM
ryans590's Avatar
ryans590
in the dodge ram faq thred at the top pf the thred page it says this
surging in overdrive at hiway speeds: (Racinfan83)
tps is noisy and needs to be replaced. the signal a noisy tps sends back to the pcm tells it that the throttle is open farther than it really is and the pcm unlocks the torque converter. the surging is about 200 rpms as the TC locks and un-locks.
mine is doing it too but this sounded more like this it hope it helps
Old Jan 21, 2006 | 08:36 PM
Socha_62's Avatar
Socha_62
RPMs stay steady. And I've checked my TPS with a multimeter before, its within specifications
Old Jan 22, 2006 | 01:53 PM
NJ Diesel's Avatar
NJ Diesel
I have a 99 2500 Cummins and A friend has a 1998 2500 Cummins they were both doing it and he got underneath and cleaned the plug into the side of the trans and he said it cured this problem. I don't remember what plug it was for, but he said if dirt or oil gets into the prongs it will cause this problem, more so in cold weather.
Old Jan 22, 2006 | 09:33 PM
Fiero Guy's Avatar
Fiero Guy
I had the same problem, could pretty easily tell that it was the torque converting unlocking though.
Replaced the TPS and its fine now.
Old Jan 22, 2006 | 11:03 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: NJ Diesel
Sounds like the speed sensor...it's often the cause when the TPS isn't.
It's a common problem on Jeeps [>:] My uncle had both go at the same time on his Cherokee...caused all sorts of odd problems.
Old Jan 23, 2006 | 05:08 AM
Duffs302's Avatar
Duffs302
Mine does it at 40 mph
