Paint
Old Jan 22, 2006 | 08:49 PM
Dodge4x4810's Avatar
Dodge4x4810
Default Paint
I was wondering what the best way to go about painting was. I have rust on each side of the bumper in the corners and a little underneath the bumper too. I also have a little under the the driver's side door, but that really isn't that noticeable. Should i just sand it, repaint it and put clear coat on it. Or is there some sort of spray that will stop rust or slow it down that i can put on before paint???
Thanks
Old Jan 22, 2006 | 10:12 PM
motodog1's Avatar
motodog1
Default RE: Paint
theres a cool new product on the market called por-15 once applied it invelopes the rust to create s seal that the rust will not work its way back through.if its surface rust your dealin with just sand it of use a good metal etch primer on any bare steel then prime and paint.....
Old Jan 22, 2006 | 11:17 PM
shott8283's Avatar
shott8283
Default RE: Paint
second that idea.... all paint and body work is 90% prep and 10% paint... if you dont prep good enough itll turn out crappy and rust will eat through
Old Jan 23, 2006 | 01:32 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: Paint
Don't use por. I've talked to several body shop guys that have used it, and they say it's hard to work with.
They recommended this to me instead: http://www.magnetpaints.com/underbody.asp
Haven't gotten to try it yet, but I plan on doing the whole frame on my V10 when I get a chance...and by chance, I mean the $$$ to buy enough and the time to take the box/doghouse off. [8D]
Old Jan 23, 2006 | 03:47 AM
Socha_62's Avatar
Socha_62
Default RE: Paint
I painted the entire underbody of a Jeep this summer with Por-15, and I thought it was sweet. Its suppose to be really go from what I hear, and I didn;t have a problem working with it at all. For a professional quality color match paint try http://www.expresspaint.com/ I got it for the rust on the bottom of my drivers door. It matches perfectly and seems really nice. You do need a Urethane Reducer to mix with it though, but its not to pricy for that. The paint itself is damn expensive since its color match. I paid $50 for 1/2 a pint! They have a few diffrent types of paint. Make sure to get the good stuff.
Sand it down, or sand blasting works best, and put a good rest preventative primer on there. A few coats. Then a few coats of the paint, and some clear coat. Good as new, literially!!!
