Weird Problem?
Ok, I having a little bit of a problem. I am just starting to Mod my Truck slowly, I have already added a K&N Drop and I just added a Flowmaster 50 Series yesterday. Here's the problem, When I start from the line, or when I pump the gas in Park, it seems to mis fire between 1500 to 2200 RPM. Just started doing this about 300 Miles ago. I thought it might be the tranny but it does it even if I pump the gas in park. Does any body have any clues. I haven't tried looking to the plenum gasket, could this be the problem?
Thank,
DMan.
Thank,
DMan.
May want to check the routing of your wires, maybe touching and causing the miss. I would make sure all plug & distributor boots are secure and the coil wire is secure also. How old are the plugs, wires, cap and rotor?
Ok, I just looked and it does look like the plenum gasket could be out, still not sure if this is what causing my problems. Ok, it looks like I am going to be changing the plenum gasket, now the question, I have heard to some Intake Manifolds do away from the gasket, Like Mopar and Edelbrock's ( I Think), for the money would it be wise to just order a Intake Manifold, or just replace the gasket? At looking at the price it's a few hundred more for the intake, What benefits would I get with replacing to whole intake. I was looking at summit Racing and found a Edelbrock's Performer RPM Air-Gap intake manifold for less then $300, Is this a good intake? Any Problems with intakes would I lose any low end or gain top end. Any comments would help.
Thanks again,
DMan
Thanks again,
DMan
u 100% sure that it is your plenum, if its bad you see oil leaking in from the gasket, there should be a little debris and grim down there because the breather house routes back into there.
Trending Topics
nah, more like a freeflowing exhaust. Backpressure is a funny thing, you will always hear those high performance engines backfire cause they run open pipes just about. My jeep had the same thing, it would backfire when I jumped on it when it was out of gear. 4 bangers with high flow cat and flowmaster muffler...
