truck setup...
Old Feb 7, 2006 | 03:09 AM
  #21
shott8283's Avatar
shott8283
Default RE: truck setup...
how did it run any better? any difference?
Old Feb 7, 2006 | 03:31 PM
  #22
Racinfan83's Avatar
Racinfan83
Not that I could tell yet. I go back to work today, long drive on highway, maybe I'll notice something. It my be hard for me to tell, however, cause I'm still getting used to the extra power my Hypertech gave me when I programmed it last week. The PCV valve is on the opposite valve cover and goes to a fitting on the side of the intake.
Old Feb 7, 2006 | 03:44 PM
  #23
steve05ram360's Avatar
steve05ram360
cool, that's exactly the way I was going to do it when I get a K&N filter for it. The way I look at it, that hose connection is there to draw air out of the motor which is hot. that hot oily air will increase your intake air temp slightly causing a slight drop in power.
I know every time I pull mine off and plug the intake side, it runs better, mines just not filtered so it doesnt stay that way long. I need to start a list of things for summit racing and include that filter as one of the things on the list.
Old Feb 7, 2006 | 03:55 PM
  #24
Racinfan83's Avatar
Racinfan83
Yeah, I'm not sure how the PCV valve works on the other side - help refresh me?? The hose from it goes directly into the intake manifold, so I assume there is some bad air still going in. I know on race cars they use exhaust vacuum to pull the crankcase gases out, by eliminating the hose like I did I am a little concerned that the engine may not be evacuating properly, even though is has a "breathable" filter on it now. Any engineers out there have an idea on this?
Old Feb 8, 2006 | 02:50 AM
  #25
shott8283's Avatar
shott8283
i just tested it tonight..no filter but just pluging it...smoothed the idle out just a littel bit... didnt drive it though... .. im gonna get a new filiter instead of using the one laying around the garage...
Old Feb 9, 2006 | 03:04 PM
  #26
RM_Indy's Avatar
RM_Indy
Nice setup you have Steve!
The vent breather filter should help a little bit with mileage/performance. Not sure if I missed it but adding the filter instead of the breather tube into your intake could fail an etest if they are **** (Cali for sure).
Old Feb 9, 2006 | 03:53 PM
  #27
steve05ram360
ORIGINAL: RM_Indy
Thanks!
Yup, it would fail the visual for sure. but it's only a hose and a breather and would only take a minute to swap out.
Old Feb 9, 2006 | 04:16 PM
  #28
Racinfan83's Avatar
Racinfan83
Ok, with that being said, considering I still have the stock air cleaner with the K&N drop-in, They have small breather filters that would fit on the fitting on the air cleaner that I removed the breather hose from. Instead of capping that hole, would it be beneficial to install one of these small filters ($10) for a little more air flow, or not?
Old Feb 9, 2006 | 04:41 PM
  #29
steve05ram360
probably not... it would be more of a PITA to keep it maintained I would think. cap it off and get a bigger air filter. I have a 6x7" round filter that helps out a lot with the top end and even slightly on the low end. i'd recommend going that route or something in between the stock cone & the bigger one I mentioned. (this assuming you have the K&N FIPK)
Old Feb 9, 2006 | 05:01 PM
  #30
Racinfan83's Avatar
Racinfan83
Nope, No FIPK....Yet! Like I mentioned earlier, I really haven't been able to tell if this made any difference because of the big change I am noticing now from my new Hypertech.....
