Clunk when i let off the brakes.
Old Feb 4, 2006 | 05:55 PM
nmason's Avatar
nmason
Default Clunk when i let off the brakes.
for the last couple weeks if i pull up to a stop, when i take my foot off the brake i get a clunk that is VERY noticeable. i know im not far off from needing new pads on the front, but i have a feeling its coming from the rear drums. what causing it?
Old Feb 4, 2006 | 06:56 PM
Racinfan83's Avatar
Racinfan83
Default RE: Clunk when i let off the brakes.
First thing I'd check is the front brake caliper mounting bolts. Bad deal if one of them falls out! Just for info purposes, new front rotors are $30 apiece at NAPA, pads are around $30. Easy to change them yourself. I had a local chain auto service center give me a $468 estimate to do what cost me $90, two beers, and an hour and a half.
You could also have a broken return spring in one of your rear brakes.
Old Feb 4, 2006 | 07:02 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
I get that clunk too from time to time. I know for a fact that it is coming from the rear of the truck, but can't tell where. I am thinking rear brakes, but have never been able to pinpoint it.
Old Feb 4, 2006 | 07:08 PM
shott8283's Avatar
shott8283
new front rotors are only 30 a peice from napa? crap i got ripped off
along with any kind of driveline clunk... check the u joints... how many miles does your truck have and have you had the u joints replaced or are they original... go under neath and see if you can grasp the drive shaft and twist it... if it twists more then a half inch then your unjoints will need replacing...
i think its prolly the brakes or something along that line but never hurt to check the u joints..after seeing what a f150 does with a driveshaft falling out and wipping all over the under careage after a u joint went to come failure.. i always check
Old Feb 4, 2006 | 08:04 PM
Racinfan83's Avatar
Racinfan83
ORIGINAL: shott8283
Yeah, I got rotors, pads, a can of Brakleen, and some caliper grease for like $100 total bill.........
Old Feb 5, 2006 | 01:09 AM
palo35's Avatar
palo35
I had that clunking noise too. It came from the rear drum, passenger side. A spring had broken. It never made a noise unless it was under pressure from breaking. I figured it was the brake shoe adjusting itself, maybe not. Anyways put new shoes on and the clunk went away. By the way, my front rotors cost me 49 bills each! But then i have a big ol 2500 V10. Still cost me under 160 bucks to do it myself instead of the midas guy charging me $550. good luck locating your issue. U joints always a good thing to check when you got noise in the rearend.
Old Feb 5, 2006 | 03:16 AM
shott8283's Avatar
shott8283
holy crap...i paid 99 a peice for my front rotors... and 80 a peice for the rear drums... damn i got hosed tommy...i got hosed
Old Feb 5, 2006 | 04:55 PM
Racinfan83's Avatar
Racinfan83
Dude you need to go back there and ask for Vaseline! I don't know how much drums are, haven't done that yet.
Old Feb 5, 2006 | 05:27 PM
shott8283's Avatar
shott8283
yea dude i got raped hardcore
Old Feb 5, 2006 | 08:47 PM
BigRedRam's Avatar
BigRedRam
i had the same problem with mine, and after changing rotors and brakes all the way around, i think it was due to an uneven spot worn in one of my rear brakes
