drivetrain switch
Old Feb 5, 2006 | 12:47 PM
MCDiver's Avatar
MCDiver
Default drivetrain switch
I have a 97 with a engine noise and have the opportunity to purchase a 2000 (totaled) with a good motor and tranny for cheap. My question is: Will the newer system fit in the 97 and if so are there any modifications that need to be done?
Mike
Old Feb 5, 2006 | 01:55 PM
Socha_62's Avatar
Socha_62
Default RE: drivetrain switch
What size do you have and what size is the 2000? If they're both the same you will not have a problem. I'm assuming the trannies are the same too.
Old Feb 5, 2006 | 02:01 PM
MCDiver's Avatar
MCDiver
In this case, I can that I do not think size matters. I have the entire drivetrain to work with. My question revolver around the FI system, computer, etc. Is this a direct replacement? I have been told that the two years used the same drivetrain and was courious if this was true.
Mike
Old Feb 6, 2006 | 02:48 AM
Socha_62's Avatar
Socha_62
There are seperate comps for the 5.2 and 5.9, so I'd swap the comps to just for the hell of it. It should all bolt right up.
Old Feb 6, 2006 | 03:29 AM
shott8283's Avatar
shott8283
i agree... physicall specs are the same... meaning the the engine is 10 inches tall... its the same for both... i really cant think of any problem youll have .. just the PCM... youll have to use the new one with it
Old Feb 7, 2006 | 12:28 AM
MCDiver's Avatar
MCDiver
Great!
Thanks for all of your help!!
Mike
