problem with stereo
Old Feb 14, 2006 | 12:12 AM
jimboo_900's Avatar
jimboo_900
Default problem with stereo
i just bought a used jvc from and friend and have been trying to install it in my 1999 dodge ram 1500. so i went out and bought a wiring harness from wal mart. i connected all the wires together but i only get power to the head unit and no sound will come out any of the speakers. with the stock stereo everything works fine. i was just wondering if anyone has had the same problem or if i doing something wrong.
Old Feb 14, 2006 | 12:17 AM
ryans590's Avatar
ryans590
Default RE: problem with stereo
do you have the infinity system? i herd something about there being a factory amp that has to me turned on and the stock one duz but aftermarket duzent also are you shure the sterieo you bought works lol you sed its used
Old Feb 14, 2006 | 12:24 AM
jimboo_900's Avatar
jimboo_900
ya i have the infinity system. you dont happen to know where the amp is do you??
the stereo worked in my friends car..
Old Feb 14, 2006 | 12:27 AM
ryans590's Avatar
ryans590
the amp is behind the glove box i think
Old Feb 14, 2006 | 12:28 AM
theshocker's Avatar
theshocker
If I remember correctly you have to hook up both of the remote wires(blue) coming from the harness. One turns the tuner on and the other turns the amp on. I didn't have the infinity system and still had to do this. Kind of wierd.[&:]
Old Feb 14, 2006 | 12:43 AM
jimboo_900's Avatar
jimboo_900
where do i hook the blue wires to because i think all the stock wires are hooked up.
Old Feb 14, 2006 | 01:29 AM
20dodgeram01's Avatar
20dodgeram01
well im glad you decided to use a wire harness. i bought a new head unit and tried wiring up myself my splicing the wires and all. turned out i had all the wires backwards and fired the head unit [:@] so i got a new one and payed circuit city 100 bucks to install it for me. i didnt understand the dodge wiring colors at all so i got it all screwed up.
Old Feb 14, 2006 | 04:09 AM
habeba86's Avatar
habeba86
http://www.installdr.com/Harnesses/DCP-Wiring.pdf
That tells wat wire to hook up to get the factory amp to work.
Old Feb 14, 2006 | 09:19 PM
jimboo_900's Avatar
jimboo_900
thanks that really helps..
Old Feb 15, 2006 | 04:00 AM
habeba86's Avatar
habeba86
let me know if you have any problems, audio is wat I do best.
