4x4 problem
Old Feb 14, 2006 | 06:05 AM
habeba86's Avatar
habeba86
Default 4x4 problem
When i put my truck into 4 hi it engages fine work fine sounds fine, but when i put it back into 2 it does 1 of 2 things. 1. The 4wd light goes off but stays in 4hi 2. It doesnt do anything and the light stays on. I have found that if I put the truck in 2wd and back up a bit it will come out of 4wd. I was jst wondering if anyone knew what it could possibly be?
98 sport 5.2 I can look at wat kind of gears I got if you guys need me to. Thanx
Old Feb 14, 2006 | 02:46 PM
cdusthockey's Avatar
cdusthockey
Default RE: 4x4 problem
I have the same problem with my truck from time to time, but usuallyi just need to come to a stop and it disengages. sometimes if you let off the gas it will release i have found
Old Feb 14, 2006 | 05:18 PM
Racinfan83's Avatar
Racinfan83
Yeah, either stop or stop and back up a bit. I do that anyway because I'm used to having lockouts on all my other trucks before. The reason is that you still have enough tension from the forward motion to keep the axle "locked in" until you stop or reverse to release the tension. You don't have a problem...
Old Feb 14, 2006 | 11:57 PM
rogerdoger's Avatar
rogerdoger
same thing here.. i usually just throw it back into 4x4 and then take it out.. that usually fixs it,,,,,
Old Feb 15, 2006 | 12:11 AM
turbot_bird's Avatar
turbot_bird
I always back up too. all my other vehicles I had too ecept my old 79 chevy I had manual lockers on it
Old Feb 15, 2006 | 03:58 AM
habeba86's Avatar
habeba86
coo. thanx for the help guys!
Old Feb 15, 2006 | 09:04 AM
Ram_Sport's Avatar
Ram_Sport
the way i get outta 4 is either 1 of two ways, while cruising disengages and let of for a bit till u hear the front end disengage, or while at a stop light put it back in 2 and toss it in reverse then back in drive and tada,
