Engine Shut off will not start.
Old Feb 23, 2006 | 06:14 PM
nichad's Avatar
nichad
Default Engine Shut off will not start.
I was driving my 97 1500 Ram 5.2 up a fairly steep highway when all of a sudden it lost all power and shut off. It will not start back. Just wondering where I need to start looking. The engine will turn over just will not crank. Thanks.
Old Feb 23, 2006 | 08:05 PM
steve05ram360's Avatar
steve05ram360
Default RE: Engine Shut off will not start.
welcome to DF...
check your fuel pump. turn the key on and listen for the pump to turn on for about 2 seconds. no sound, need a new pump. other possiblities include crank sensor and cam sensors. the motors basic needs are air fuel & spark so one of those is not there. look for something that is going to affect all 8 cylinders... meaning it's not a wire issue and is most likely not a cap/rotor issue.
good luck and hit us up if you have any other questions...
Old Feb 23, 2006 | 09:14 PM
nichad's Avatar
nichad
Thanks for the reply. I was thinking fuel pump as well after I got the truck to run a few seconds by putting some gas straight to the the throttle body. Am I right in thinking the pump is in the fuel tank? Thanks.
Old Feb 23, 2006 | 09:26 PM
steve05ram360
yup... I just swapped one myself...
here's a diy wrietup... https://dodgeforum.com/m_402587/tm.htm if you need any guidance...
Old Feb 23, 2006 | 10:05 PM
nichad's Avatar
nichad
Thanks again! Those instructions are awesome. I will let you know how I fair. Thanks.
Old Feb 24, 2006 | 02:08 AM
Socha_62's Avatar
Socha_62
Check that cat out too. Mine did that when I was on the highway. Stalled out and had a hell of a time starting and when it did start, giving it any throttle killed it.
Old Feb 27, 2006 | 02:43 AM
nichad's Avatar
nichad
Wanted to let Steve00ram360 know because of his assistance I got my truck back on the road today. I really appreciate your help and let you know I could not have done it without you. I am new to this forum, but with folks like Steve here it has got to be top notch! Thanks again.
Chad
Old Feb 27, 2006 | 03:08 AM
steve05ram360
Glad to hear it's on the road again...
So it was the fuel pump? how long did it take you to swap it?
Old Feb 27, 2006 | 12:00 PM
nichad's Avatar
nichad
By the time I ran to get the new pump it was between 2-3 hours. Your directions were spot-on. Thanks again.
