turn signals both sides blinking real fast....
Old Feb 26, 2006 | 08:47 AM
Viper32's Avatar
Viper32
Default turn signals both sides blinking real fast....
I have checked bulbs all are good, but the flashing is really fast like a bulb is out any ideas what to look for? 97 Dodge Ram 1500
Viper
Old Feb 26, 2006 | 03:54 PM
BigRigTruckin66's Avatar
BigRigTruckin66
Default RE: turn signals both sides blinking real fast....
Don't quote me on this, but it may be a short in the electrical flow. You were right in checkin' the bulbs, and if they're good, I would try and get the wires checked for any decay and corrosion.
Old Feb 26, 2006 | 04:44 PM
The Burning Rom's Avatar
The Burning Rom
Try replacing the flasher unit first. Make sure you get a heavy duty flasher unit. IIRC, the HD ones have a DOT number on them.
Old Feb 26, 2006 | 04:54 PM
ryans590's Avatar
ryans590
yah id say flasher too its a 97 so you should have 2 of em 1 on the front of the fusepanel and one on the back front one is for turn sigs back one is for hazards. if you wanna test it out turn your hazards on, if they flash normal then take the hazard flasher and swich it with the sig one and if it flashes normal then its deffanatly the flasher
Old Feb 27, 2006 | 02:04 AM
shott8283's Avatar
shott8283
check your grounds too..if a flasher isnt grounded correctly or well... the relay seleniod inside them acts speractic like your describing...more then likley just a bad blinker relay (flasher) but if you swap one out for a new one and still acts up check out your grounds
Old Feb 27, 2006 | 06:14 AM
Chopper1's Avatar
Chopper1
As the flasher gets older and weaker lights will blink faster. Easy sign that it's time to replace it. Put a trailer on it and watch how fast it goes.....
Old Feb 27, 2006 | 11:34 AM
greenmachine's Avatar
greenmachine
It could be that you already have a heavy duty flasher in it for towing purposes. As you add more lights the flashing slows that is why your heavy flashers blink faster.
Old Feb 27, 2006 | 03:32 PM
shott8283's Avatar
shott8283
very true but it would blink fast all the time instead of just starting
