lack of power
Old Mar 4, 2006 | 02:53 AM
  #21
Ram1500Dodge's Avatar
Ram1500Dodge
Default RE: lack of power
ORIGINAL: ryans590
ORIGINAL: Ram1500Dodge
ORIGINAL: ryans590
dont mean to steal the thread, but i got the same damn problem, 97, 5.2, ext. cab, 4x4.....cant even power brake the damn thing, single inlet to dual outlet 2.5 i believe, 32x11.50x15 tires
what gears are you running?
i really have no idea
well since you dont know im asuming you havent changed them so have a 98 5.2 4x4 and stock is 3.55 gears prob what you have unles you have an offroad edtion so your tires should be ok for that tire size. is it pretty much stock? any modds? with the 5.2 you wont be spinning your tires all over the place i mean i can squak them with mine but nouthing spectaculer
completely stock, not offroad edition, i can get a tire to break loose if i punch it while turning or in the rain, are yall able to power brake? it doesnt really bother me that i cant spin the tires over, but i just feel as if my truck isnt fulfilling its potential, and id like to outrun grandmas station wagon at redlight atleast once, you know.
Old Mar 4, 2006 | 08:12 AM
  #22
jalapeenoz's Avatar
jalapeenoz
I have 31 inch tires and crappy 3.21 gears and I have no problems breaking the tire loose off the line. If the roads are slick sometimes going into 2nd too. Gotta love the stick!
Old Mar 4, 2006 | 03:24 PM
  #23
Socha_62's Avatar
Socha_62
3.92 is also a gear option, not only 3.55 I have 3.92's in mine and its not an Off Road. It does seem like most truck from the factory come with 3.55's though.
Old Mar 5, 2006 | 10:38 PM
  #24
A*n*t*h*o*n*y*'s Avatar
A*n*t*h*o*n*y*
I have a 1999 2500 with a 5.9! I dont know if it is normall for these trucks to not break the tires loose but mine wont. The only time that it does is in the rain, ice, snow, or mud. I think that I have the stock gears in. Also the tire size I believe is around a 31-33 but I will check and repost tomorrow on the tire size. I have a K&N Cold air intake, and a 40 seiries single in single out flowmaster exhaust. It is a 2 1/4 " Ran out just over the rear end. I was wondering what you could do to give it more power?? i was thinking a new 180 degree thermostat?? Let me know please... thanks
Old Mar 6, 2006 | 03:06 PM
  #25
chermann's Avatar
chermann
This is a response to the original question. I had the same problem with my 99 Ram, v8 two wheel drive and manual trans. The dealer did a fast check and said the intake manifold gasket was bad. $1000 later I am back on the road and power is restored. It gets worse though. I just found out today that I have another bad intake manifold gasket. It took 30000 miles to destroy the first one and 13000 miles to destroy the second one. I can infer from this that Dodge can't build a motor any more. I am done with Dodge and want to get rid of my truck. If you do a google search for "engine ping dodge" you can learn the gory details. I will never buy Dodge again!![X(]
Old Mar 6, 2006 | 03:14 PM
  #26
A*n*t*h*o*n*y*
That Totaly sucks.. how many miles did you have on the engine?? Oh yeah my tires are 285/75/16
Old Mar 6, 2006 | 03:22 PM
  #27
mopowar's Avatar
mopowar
All trucks/cars have inherent manufacturing problems/ design flaws. The intake is one of Dodge's. Fix it the way descibed in many posts here and you will not have any more problems out of it. Get the aluminum belly pan from apsprecision.com and follow the directions. Trash the metal gasket that comes with the kit and get the Felpro gasket.
You don't have to Google anything. Use the search function here, and you will find more info on that belly pan gasket than you want or have time to read.
