coolant/t-stat problem-- UPDATE
Old Mar 1, 2006 | 02:42 PM
  #21
MARC276CA's Avatar
MARC276CA
Default RE: coolant/t-stat problem
hi,
go directly with dealer thermostat, and not aftermarket offshore products, unless you will enjoy erratic temp gage and leaking housing gasket, also there is an actual visible and weight difference between both parts, noticeably the spring is heavier.
Greasemonkey.
Old Mar 1, 2006 | 03:23 PM
  #22
shott8283's Avatar
shott8283
ur saying go to dodge and get their 180deg thermo?
i think steve is runnin tha napa brand and hasnt had any problems
Old Mar 1, 2006 | 03:40 PM
  #23
steve05ram360's Avatar
steve05ram360
I get most of my stuff from Napa... however I think the t-stat that's in there now is an autozone one and i've had NO cooling problems related to the t-stat. (I think my rad has a leak)
Old Mar 1, 2006 | 04:10 PM
  #24
Socha_62's Avatar
Socha_62
26 gallons?! Crap I thought they were 36 gallons and thats what I figured them at. YAHOO my MPG just went up ha!
Old Mar 1, 2006 | 04:23 PM
  #25
steve05ram360
lol, hey man, sorry to burst your bubble... but your mpg still = miles traveled/gallons used... so it doesnt matter if your tanks 100 gallons... your mpg calculation is the same.
the only thing you may need to adjust for is error in the odometer. tires & gearing affect the odometer readings, meaning if you have oversized tires, your odometer is not 100% of the distance traveled...
Old Mar 1, 2006 | 04:28 PM
  #26
shott8283's Avatar
shott8283
leakin rad? rutrow raggy!!!!
Old Mar 1, 2006 | 04:55 PM
  #27
Gary-L's Avatar
Gary-L
Veteran: Navy
I have always done the afore-mentioned when the t-stat was changed, but when the temperature starts to rise, turn the heater on full blast. That will help circulate the coolant and bleed the air. I've never drilled a small "burp" hole.
Old Mar 1, 2006 | 05:01 PM
  #28
shott8283's Avatar
shott8283
thats what the book said to do is turn the heater on bull flast to get the entire system flowing... i did it but didnt help
Old Mar 2, 2006 | 12:00 AM
  #29
shott8283's Avatar
shott8283
incase anyone was ever wondering this is what an open t-stat looks like... i did a full function check of the napa one i bought today that hopefully i can get in tomorow... pretty interesting... i did this check about 30 times... made the tstat actuat using a boiling pot (not really boiling but simmerd around 200 degs) and then took it out to cool it down and let it open and close
sorry bout the picture quality...kind ahrd to hold that hot little thing and still get the camera to focus on it
[IMG]local://upfiles/3936/75C88EC04B8142ABAEF7E59DB91D4207.jpg[/IMG]
Old Mar 2, 2006 | 12:35 AM
  #30
Dodgeramman's Avatar
Dodgeramman
You know Ryan There is something about this that sound so familiar. What was it! Oh yeah My gauge, still all over the place jumps up to 200 drops down almost to 130 then up. Takes a while to warm up the heater too. WTF cant figure it out. Guess I will have to yank the damn thing off again and drill it. Delt with it for awhile, its only 10 miles to work. But this past week it sucked as cold as it was. Used to warm up in about a mile now 4. So like you probably got air in there. Opens fine, did the water test before I put it in.
By the way update the points please your a little behind, they lost again.
