noise when cutting wheel
Old Mar 2, 2006 | 12:32 PM
young buck's Avatar
young buck
Default noise when cutting wheel
ive been hearing a grinding noise in the front end of my truck when i cut the wheel mainly to the right is when i hear it but it will happen sometimes when i fire it up and its cold when i put it in gear does anyone know what this is?
Old Mar 2, 2006 | 05:04 PM
Socha_62's Avatar
Socha_62
Default RE: noise when cutting wheel
Sounds to me like some tire rubbing. Mine did that when I first got it and couldn't fifure out what it was. Rubs on my lower control arm drivers side
Old Mar 3, 2006 | 02:05 AM
badram1500's Avatar
badram1500
check out the wheel bearings. If it is a 4wd check the u-joints on the end of the axles.
Old Mar 3, 2006 | 02:15 AM
ryans590's Avatar
ryans590
check your front axle u-joints too while your under there ive had bad luck with them
Old Mar 3, 2006 | 12:19 PM
young buck's Avatar
young buck
ok thanx alot guys when i change my wheels ill look at them
Old Mar 3, 2006 | 03:30 PM
Redneck2345's Avatar
Redneck2345
when my wheel bearing went out it started squeeking for about a week and than splat out on the side of the highway on the 3rd of july (good luck finding parts on the 4th)
Im going to guess that its a u-joint binding up, maybe replace those first as they are the cheapest, and the wheel bearings are super easy to get to at anytime
