fastman tb
Old Mar 9, 2006 | 07:35 PM
  #21
Racinfan83's Avatar
Racinfan83
Default RE: fastman tb
ORIGINAL: steve00ram360
This 50/52mm debate has me thinking... if your only opening the throttle part way during acceleration, wouldnt the 52mm flow the same at a lesser throttle position and still give the same amount of torque?
really what i'm trying to get at is I think the 50mm vs 52mm is only obvious at WOT... the motor will only flow a maximum amount of air at whatever it's current bottleneck is... at WOT, if you have a small filter then your limited by what that filter will flow, same for the exhaust, small exhaust would have the same affect. open them up and then you move the bottle neck somewhere else (heads, intake TB etc)
what do you guys think?
BTW, the fastman was one of my best mods...!
AND - to add to this - you are restricted on all of the above by the cam lift profile, compression ratio, piston configuration, valve size, etc. The key to getting higher performance is to make every component work perfectly with each other to maximize flow through the engine at high rpms. Since most of us are limited by what the Dodge engineers put IN our engines, you have to keep that in mind. It's like putting a 1000cfm Dominator carb on a stock 360. It will run - but not efficiently........
Old Mar 9, 2006 | 08:56 PM
  #22
Off_Road_Teacher's Avatar
Off_Road_Teacher
ORIGINAL: muddy_blue_dodge
Off_Road_Teacher-
you said you did a 0-60 test- you said stated the difference between the ebay tb and the fastman, but did you record the difference between the fastman and stock? if so please post it.
I wish that I had tested them against stock in hindsight. But I never did, and I sold my stock tb, so I can't even do it now. If I do ever come across a stock tb for a 5.2, I will be sure to compare the three. Without any numbers, I will say that the aftermarket tb's made a big difference off the line over stock.
Old Mar 9, 2006 | 10:15 PM
  #23
Bassman's Avatar
Bassman
I think the 50mm works better on the 5.2 engine because all though a 52mm will flow more volume it will flow with less velocity therefore killing some bottom end. Larger hole=less velocity more volume= better Top end power for high rpm
Old Mar 10, 2006 | 12:23 AM
  #24
20dodgeram01's Avatar
20dodgeram01
sounds like its a really good investment.. hopefully i can get it for under 300 though because i can only put 300 bucks a day on my debit card and i have no idea how else to buy it
Old Mar 10, 2006 | 06:51 AM
  #25
Racinfan83's Avatar
Racinfan83
ORIGINAL: 20dodgeram01
Call Dan and explain this to him and he'll probably be able to work something out. I would think maybe he could charge you the price one day and the core the next day or something. Just talk to him - he's cool and very knowledgeable.
Old Mar 10, 2006 | 03:37 PM
  #26
A*n*t*h*o*n*y*'s Avatar
A*n*t*h*o*n*y*
Sorry Wilie C.. I had a severe blonde moment on that one!! I ment that driving with the o/d on in town is said to be bad. I dont know what the heck I was thinking on that one sorry man.[sm=icon_quiet.gif] also I was wondering where are you guys going to get the fastman tb's??
Old Mar 10, 2006 | 03:40 PM
  #27
muddy_blue_dodge's Avatar
muddy_blue_dodge
theres a link to the site to order them on the right side of this page- where those advertisements are.
Old Mar 10, 2006 | 03:44 PM
  #28
A*n*t*h*o*n*y*
Thanks man... I never even looked over there... Figures!! U notice a big differece on urs?
