Changed WaterPump and now overheating.....
Old Mar 14, 2006 | 01:32 AM
Viper32's Avatar
Viper32
Default RE: Changed WaterPump and now overheating.....
Yes its the correct waterpump. Also the thermo is opening I can feel the top hose get hot. Below is something I forgot about......
I did forget one thing to tell when I changed the waterpump. I also changed the lower hose since it looked shabby. One difference in it and the original was it did not have a spring inside it like the one that was on it. Is this normal? Could the hose be collapsing when I am driving causing this overheating problem?
Mark
Old Mar 14, 2006 | 01:52 AM
shott8283's Avatar
shott8283
oh yea.... theres a vacume present when the motor is running.. the higher the rpm the greater the vacume... thats how the rad cap actuates and allows the resevior to add coolant... thats why if your low on coolant and just fill the resevior tank it fills that way... after you open the rad cap that vacume takes a bit to start back up... like a few start ups... anyway that vacume can be strong enough to collapse non-structure hoses... especially the lower hose where its sucking the coolant in as apposed to the upper hose thats pushing it out...
that would seriously explain why it does it when you drive... you can do the same thing parked..just run the motor higher then idle..around the same rpm youd be lookin at when your drivin under the conditions that cause the overheating... ie: if it overheats when your doing 70 at 2300 rpm then mimick that while parked.. run the motor at 2300 rpm for a bit and have someone check that hose... just use caution and moniter the gauge closely!
Old Mar 14, 2006 | 03:55 PM
MARC276CA's Avatar
MARC276CA
is the serp belt routed for the water pump to rotate in the rite direction?
Old Mar 14, 2006 | 06:23 PM
shott8283's Avatar
shott8283
good point... check to make sure that its routed correctly... although i think it would kinda hard to route it incorrectly...its a pita to get it on the right way to begin with..
Old Mar 14, 2006 | 11:53 PM
Viper32's Avatar
Viper32
Well guys I am still at a loss. I searched everywere today for a hose with the spring and none are available around here. I would take the old spring out but its in real bad shape. I am not sure this is whats happening anyways. I did today try to burp the system and got no results. I have a 180 thermo, new pump, and still when driving with the air on I get to 210-240 degrees.
Mark
Old Mar 15, 2006 | 12:13 AM
shott8283's Avatar
shott8283
assuming you have already tried your local stealership?
Old Mar 15, 2006 | 01:35 PM
MikeNAmyS's Avatar
MikeNAmyS
Did you try the flush kit.
Heck, try flushing the engine first.
Afterwards, cap it all off and run it on just water.
Try to figure out the problem first before using antifreeze/coolant.
Not sure where you live, but don't leave it in there if gets below freezing.
I can't think of anything else.
The lower hose sounds like the culprit-Its the one thing that was changed that hadn't been checked-get a mopar hose and let us know.
Old Mar 15, 2006 | 01:50 PM
ryans590's Avatar
ryans590
ORIGINAL: MikeNAmyS
id use 50/50 antifreeze water mix like your susposto run. if you use just water and then get it figured out you will half to drain atleats half the water out to put in the antifreeze posabley alowing air into the system and causing more problems
Old Mar 15, 2006 | 02:35 PM
MikeNAmyS's Avatar
MikeNAmyS
Yes, but how much coolant is being lost and more money spent on new coolant evertime it gets drained?
Plus, water is easier to clean up and won't kill any of our little furry friends!
It'd be easier to get it here to look at it!
Old Mar 15, 2006 | 11:47 PM
MARC276CA's Avatar
MARC276CA
therm put in upside down??
