Leek
Old Mar 20, 2006 | 04:15 PM
big truck man's Avatar
big truck man
Default Leek
I've noticed a very small amount of tranny fluid on the ground. I don't noticed it everday and it is not much at a time (just a few drops). I check the fluid level and that looks good. I had everthing changed and filled about six months ago. I was told everything looked good then. My worry is this is a sign of something bad to come, or is it just a gasket seeping a little?
Old Mar 20, 2006 | 04:17 PM
shott8283's Avatar
shott8283
Default RE: Leek
could be the tail shaft seal... common to leak a little bit form there.. look up underneath and where the drive shaft plugs into the t-case (4X4) or the tranny (2X4) and youll see what im talkin about... if you notice some moisture there and maybe a droplet or too..id get it check out... not sure on how to change it but if you look at a haynes or chiltons..or even better yet the merry christmas thread pinned at the top of the forum..has a PDF manual you can download..thatll give ya some info on what that seal is and what it takes to change it
Old Mar 20, 2006 | 04:25 PM
Chopper1's Avatar
Chopper1
Default RE: Leek
Hopefully might just need to snug up the pan bolts. If you had the pan off, a new gasket could have sofened. Wipe it down and see where it is coming from.
