thermostat help real quick!!
Old Mar 24, 2006 | 05:58 PM
20dodgeram01's Avatar
20dodgeram01
Default thermostat help real quick!!
where are you suppose to drill the hole in the 180 degree thermostats?? and what size?? i just got it today and am about to work on it thanks!
Old Mar 24, 2006 | 06:04 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: thermostat help real quick!!
It's in this post:
https://dodgeforum.com/m_424213/tm.htm
Old Mar 24, 2006 | 06:07 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I've never drilled a thermostat and never had any problems. Just take your time in burping the system. Once the engine starts warming up, move the heater control full hot and turn the blower on full blast.
Old Mar 24, 2006 | 06:13 PM
shott8283's Avatar
shott8283
the litle holes helped me out alot when i had a hard time buring the system
Old Mar 24, 2006 | 06:46 PM
20dodgeram01
still doesnt give me a good idea of where the hole is suppose to go.. does it get drilled threw the thin metal going around the stat or does it go in the stat? if so then im really not trying to screw up this one lol
Old Mar 24, 2006 | 06:51 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
If you insist on drilling, a small hole through the flat, thin metal. DO NOT drill through the pellet or the housing.
Old Mar 24, 2006 | 06:58 PM
20dodgeram01
well i tried taking a look at it.. and its wayyy to confusing for me i have no idea how to get to it.. i can see where it is but it would take me hours to get to it
Old Mar 24, 2006 | 11:49 PM
ryans590's Avatar
ryans590
if your going to drill a hole do it on any of the flat part use a 1/16 drill bit, i do it seams to help burping the system even if it duzent its not gonna hurt anything
Old Mar 25, 2006 | 02:40 AM
shott8283's Avatar
shott8283
if you havnt removed the tstat before then it may be a bit tricky...the housing has a little tab letting you know what direction it goes...with that tab being there it makes it a PITA to take out b/c it gets hung up... still not hard just gotta take out the alt and unbolt the hoses (just the retainers) going to the ac pump and unbolt that too... and then you only prolly gotta loosen up a bunch of the braket bolts and kinda tug it out of the way .. and then there should ne anouf room...while you have the housing out its a good idea to grind off that tab so you can get to it later... w/o tearing down so badly..
you MAY be able to get it out with just taking off the alt... take it a step at a time...
Old Mar 26, 2006 | 04:26 AM
20dodgeram01
i was looking at it and it looks liek the alt. and a/c unit are all bolted together.. but that must be one big bracket or something i dunno.. also if i unbolt that a/c lines (the metal tubes going to the top of the a/c) will it leak out??
