HUB HELP
Old Mar 27, 2006 | 09:13 PM
Dodge4x4810's Avatar
Dodge4x4810
Default HUB HELP
I have a problem getting my right side (passenger) hub off. I am trying to replace the axle u-joint, had everything apart, everything came off fine, but the hub is frozen on. I rented a puller, 2 1/4 ton, and i broke it. Went back rented a 5 ton puller and tightened it as hard as i could and the hub did not budge, gave it some good wacks with a 5 pound sludge and everything and it still would not budge. I also used about a half bottle of pb blaster all over it. I was wondering if it was alright to use an impact gun at the end of the puller, of if anyone one ones a better way to get it off???
Thanks
Old Mar 27, 2006 | 10:03 PM
Socha_62's Avatar
Socha_62
Default RE: HUB HELP
Slide hammer, thats what I used. Poped off pretty easy, had to give it quite a few good wacks though.
Old Mar 27, 2006 | 10:44 PM
The Burning Rom's Avatar
The Burning Rom
I know of a few ways...
1.) WD-40 and a rubber mallet/deadblow hammer
2.) Gear puller <- That's what I used when I did my U-joints. Had no issues getting it off. The surfaces on mine weren't rusted though.
3.) The hub bolt trick: http://www.dieseltruckresource.com/d...threadid=62927
But if you've already tried a puller, then I'm not sure what to recommend [&:]
Old Mar 27, 2006 | 10:54 PM
GOD RAM IT's Avatar
GOD RAM IT
theres an easier cheaper way. get a deep well socket that fits the 3 bolts that hold it on(14 or 15MM 12 point I think). Do not use a shallow one because it will round the head of the bolts.
Back the bolts out about half way. Then hit the end of the bolt with the socket on there, work in a circular pattern until it is free. It is much easier to have the whole axle jacked up that way it is easier to get to all 3 bolts with a BFH by turning the steering wheel.
Old Mar 28, 2006 | 12:44 AM
shott8283's Avatar
shott8283
r u talkinb about trying to get the hub out of the knuckle race? not sure if it would help but try heating it up? i heard that bolt trick helps out alot that god ram it mentioned
Old Mar 28, 2006 | 12:49 AM
AR4CE's Avatar
AR4CE
We did mine on sat night.
Thread a bolt or two a little into the back of the hub, and hit it with an impact hammer; that should seperate the rust. (worked for both sides of mine.... 210,000 miles of original northeast rust on there)
Old Mar 28, 2006 | 01:42 AM
ryans590's Avatar
ryans590
not trying to make fun at you or anything but you did take out all the bolts right you have a 1500 so there is 3 of them there on the back side of the hub they are 9/16 (14mm) 12 point
Old Mar 28, 2006 | 01:55 AM
Dodge4x4810
Yes i took off everything, including the 3 bolts in the back that hold on the hub, i did not have any junk bolts, so i did not really hit them that hard when i threaded them in.
