4.56 gears
Old Apr 3, 2006 | 01:56 AM
20dodgeram01's Avatar
20dodgeram01
Default 4.56 gears
can somebody give me a link to where i can get 4.56 gears?? i'd really like it if you could get me directly to the part because i have no idea what gears to get for what diffrential or anything.. i have a 2001 1500 4x4.. i'd also like to know what type of differentals i have also.. i think chyrsler 7.25 and dana 60?? correct me if im wrong.. i plan on getting 305's or 315's soon.. thanks!!
Old Apr 3, 2006 | 02:01 AM
Socha_62's Avatar
Socha_62
Default RE: 4.56 gears
1500? You have a Corporate 9.25" rear and a Dana 44 up front
I am to lazy to get the direct links but here are just two sites, theres lots out there.
www.drivetraindepot.com
www.drivetrainspecialists.com
Old Apr 3, 2006 | 02:04 AM
20dodgeram01
thanks.. would you know if swapping out gears is something you can do yourself fairly easy or is this something i should get a shop to do and pay 300 bucks an axle for
Old Apr 3, 2006 | 02:06 AM
Socha_62's Avatar
Socha_62
Thats a tough question. It can get complicated when you have to adjust the spacing and backlash on them so the gears don't get to big of a worn groove on them. If you can find a good write up on them I imagine its pretty straight foward.
Old Apr 3, 2006 | 02:07 AM
20dodgeram01
http://www.drivetraindepot.com/store_axle2.asp?axle=23 alright looking at that website for the front axle gears.. i dont really understand that stuff but whats the diffrence between the 2?? (genuine gears and the other one) ones like 80 bucks more
Old Apr 3, 2006 | 02:12 AM
Socha_62's Avatar
Socha_62
I think I heard a few people say to stay away from Genuine. I guess Yukon is the way to go! Gears aren;t something you want to go stingy on as you can imagine
Old Apr 3, 2006 | 02:19 AM
The Burning Rom's Avatar
The Burning Rom
Go with YUKON.
It's something you CAN do yourself, but it's not exactly an easy process. Getting the differentials out without an axle spreader is a PITA in itself. [&:] Putting them back in isn't much fun either [:'(]
Old Apr 3, 2006 | 05:24 AM
shott8283's Avatar
shott8283
i heard with the D44 its alright to get the diff out without a spreader... its the D60's that are a realy big PITA...
thers a writeup on ps.com that shows a dude not using a spreader and just prying out the difff... not sure if its exactly the way to go but would be better then buying a housing spreader
Old Apr 3, 2006 | 06:34 AM
The Burning Rom
ORIGINAL: shott8283
I just used a pry bar when I took the differential out of my 60 to change the axle seals. It took me around 2 hours to CAREFULLY pry it out with a huge pry bar. I left one of the caps half on to catch it so it wouldn't fall out. And if you do this yourself, make sure you MARK the caps (both the side and orientation) so they go back on exactly the way the came off.
I looked at axle spreaders after I did mine. IIRC they were around $500 on eBay...at least for the kit that would allow you to do 44s, 60s, 70s, 80s, Chryslers, and GM Corporates. [>:]
Old Apr 3, 2006 | 11:37 AM
stripper's Avatar
stripper
We have the gears you are looking for. We generally sell the Motive gears or richmonds. I have never used the Yukon gears. Shoot me a PM or email and I can get you some prices.
Thanks,
Brad
