Best way to put on body lift
Old Apr 12, 2006 | 01:19 AM
2big2dodge's Avatar
2big2dodge
Default Best way to put on body lift
Whats the best way to do a body lift at home? thinkin bout gettin the 3" performance accessories.
Old Apr 12, 2006 | 02:12 AM
Socha_62's Avatar
Socha_62
Default RE: Best way to put on body lift
You need a jack and some blocks of wood. Undo one side of the bed and lift it with the jack and wood blocks just until the blocks fit and slide the bolts in (That parts a pita lining the holes up) once the bolts are in thread them in a bit (do not tighten) Then do the same for the next side. Tighten the bed down. For the cab remove the bumper (unfortunitially a must) also the steering shaft, and linkages. Pretty much do the samre thing as back.
The kits come with really detailed directions.
Old Apr 12, 2006 | 02:15 AM
iamjonnyr's Avatar
iamjonnyr
make sure you have lots of friends to help... makes things go extremely smooth.
the lift should come with very detailed instructions (as stated above)
its actually pretty easy.
Old Apr 12, 2006 | 07:37 PM
Chopper1's Avatar
Chopper1
Put mine on in a weekend taking my time being ****.... Regular tools, floor jack to lift body, torque wrench. Dealer said the body bolts torque to 60ft/lbs. Needed a friend to help hold the bumpers for alignment and to mark the holes in the rear. While he was there I had him set the rear blocks in place under the bed while I held one side up at a time. As stated before, instructions are good. Watch the tension on the wires across the rear top of engine compartment, needed to loosen the ty-raps and lower the loom to allow for engine movement.
