Water noise
Old Apr 14, 2006 | 09:41 PM
jc340's Avatar
jc340
Default Water noise
Over the last couple of weeks i have been noticing a noise that sounds like water flowing through a hose coming from under the passenger side dash, It is not a constant noise and usually does it when i get on the gas. I have since changed the radiator cap, thermostat, and checked coolant levels and hoses numerous times. I am running out of ideas and thinking of replacing the heater core. Before i go out and buy a new heater core i would like to get some more opinions from anyone who has had a problem like this or knows what it is. Any info is appreciated. Truck is 1995 dodge ram 1500 5.9l 4x4.
Old Apr 14, 2006 | 10:25 PM
JustinJohnson86's Avatar
JustinJohnson86
Default RE: Water noise
Do a search in the forums for "Faucet" ... Someone had the same problem and i think he fixed it
Old Apr 15, 2006 | 12:08 AM
20dodgeram01's Avatar
20dodgeram01
i have that problem but i only hear it on start-up.. then its fine
Old Apr 15, 2006 | 01:06 AM
shott8283's Avatar
shott8283
air bubble in the coolant system.. you could try to burp it... search burp and theres a few ways to do it... check you coolant level aswell make sure your not low
Old Apr 15, 2006 | 01:07 AM
fiveliterbtr's Avatar
fiveliterbtr
I've heard it in many different vehicles...2 main things it could be...either air in the system, air bubbles flowing thru the heater core would be audible since it's close-by...or heater core becoming plugged or a chunk of lime/calcium got lodged in there from somewhere else...backflush the core by removing the heater hoses and of course capturing the coolant in compliance with EPA guidelines :P.
Or have it done professionally, so the neighbors don't call the cops when you spill a drop.
If you have A/C, have fun if you change the heater core. It's not the easiest one on the list...
Old Apr 15, 2006 | 08:53 AM
Fiero Guy's Avatar
Fiero Guy
I was the faucet guy
https://dodgeforum.com/m_424798/tm.htm
Coolant was low when I checked in the rad itself. Took me adding coolant twice, it was down probably a quart, but the noise is completely gone now.
Old Apr 15, 2006 | 10:44 AM
nmason's Avatar
nmason
i have the same noise. there doesnt seem to be any air in the system, but if it gets low at all, noise is there, so ive gotta top it off all the time.
Old Apr 15, 2006 | 03:02 PM
jc340's Avatar
jc340
coolant level is fine and ive checked it alot. Searched "burp" but did not find anything. Can anyone explain how to "burp" it? Thanks for all the replies and keep em' coming.
Old Apr 16, 2006 | 02:20 PM
miknwv's Avatar
miknwv
I had the same problem and had the coolant replaced, it went away.
