MPG
Old Apr 19, 2006 | 01:01 PM
  #21
mopowar's Avatar
mopowar
Default RE: MPG
ORIGINAL: 65malibuss
I've already replace spark plugs, wires, cap, rotor, air filter, pcv valve and catalytic converter.
I already ordered a hypertech programmer.
I also plan on getting a cat back exhaust, cold air intake, new o2 sensors, new fuel filter.
I will also check vacuum with a vacuum gauge while driving, fuel pressure while driving.
I will also replace the intake plenum gasket.
After doing all that if I don't get at least 17 mpg I will sell it and get a Chevy.
My stinking 95 Chevy pickup with a 305 V8 with 160 horsepower and 180,000 miles had more low end torque on the highway (with 3.08 gears!) and got 17 mpg.
I've driven 1998 and 2001 Chevy's and they will blow this Dodge away as far as acceleration is concerned and still get significantly better mileage.
Mopars are good engines. DC just started detuning them rather than fixing minor inherent flaws to save on production cost. If you have a 2001, then you have the death flash. The Hypertech will improve your mileage and acceleration. Not like a custom flash, but it will help. Make sure after you do the plenum, you de-carbon the motor. Get several cans of Seafoam and use it in every way it has listed twice. If you replace the fuel filter, do the pump while your at it. Once you figure out where the filter is, you'll see what I mean. If you really have your hopes set on 17, I would plan on synthetics and keeping your foot out of it or you may be dissapointed.
Old Apr 19, 2006 | 03:42 PM
  #22
crazy1snow's Avatar
crazy1snow
Default RE: MPG
in all reality why did you buy the truck? hmm? not for the gas mileage i would assume.
hmm death flash is on my ram...... DAM
time to go shopping.
Old Apr 19, 2006 | 05:46 PM
  #23
Racinfan83's Avatar
Racinfan83
Default RE: MPG
ORIGINAL: Off_Road_Teacher
My truck must be weird or something. I average about 18 - 19 mpg on the highway with my 5.2. I have had trips where I have broken into the 20's on a few occasions. I usually go by the overhead computer, but I have also figured it out on my own several times to verify the computer's results. Every time, the computer has been dead on. Don't really know why I get such good mileage on the highway.
ORT, How fast do you drive on the highway to achieve these numbers - and how many rpm's are you turning at 70mph? I'm curious because it seems like mine gets BETTER mileage between 75-80mph than it does anywhere between 60-75 mph.......
Old Apr 19, 2006 | 05:55 PM
  #24
mopowar's Avatar
mopowar
Default RE: MPG
Any TSB's regarding the pcm prior to 2001 are on your truck if you have a 2001. I got real lucky-NOT. I have a 2000. It seems that half way through that production year is when the factory started putting the death flash on the pcm instead of reliable plenums/gaskets. At the same time they decided to put torque management on the pcm instead of fixing thier slushbucket transmissions. When was mine built? THE SECOND HALF. I was told by a Dodge mechanic that they stopped the death flash after they started putting the metal gaskets in. I'm not sure when that was.
Torque management remains, even in 3rd gens.
Old Apr 19, 2006 | 07:22 PM
  #25
Off_Road_Teacher's Avatar
Off_Road_Teacher
Default RE: MPG
ORIGINAL: Racinfan83
I am running about 1900 - 2000 rpm's at 70. To get the numbers I am getting, I have to do about 65 - 70. Any higher or lower and the mileage starts to drop off.
Old Apr 19, 2006 | 09:02 PM
  #26
big_Gymnast's Avatar
big_Gymnast
Default RE: MPG
Hey guys,
I think the 5.2 is just a gas hog in general....but then again we buy dodge because we like em, not because of the mileage. With a brand new long block 5.2 (which Dodge paid for..thank god) I'm still getting 12.8-13.6 depending on the wind conditions and my driving habits. My truck miles are 95% highway miles right now. I still have my Dakota with the 4.7 and with that I was only getting 14-16 depending on my foot. Bottom line, Dodge has never been know for good mileage, but we still have better looks and bigger ***** then all the rest!!!! Talk to you all later!!!
Evan
Old Apr 20, 2006 | 12:14 AM
  #27
2big2dodge's Avatar
2big2dodge
Default RE: MPG
I too get about 16-18 mpg. Dont ask how but i do. Maybe im just lucky.
Old Apr 20, 2006 | 01:03 AM
  #28
cableguy's Avatar
cableguy
Default RE: MPG
I'm getting about 9.9 lately. I just put the tonneu back on, so that will help a bit. I actually haven't driven it lately b/c the dash is about half torn out right now. My bro-in-laws 01 CTD get better milage than mine with the bed filled to the top and towing 6000 lbs. than mine gets nearly empty!!
Old Apr 21, 2006 | 10:29 AM
  #29
65malibuss's Avatar
65malibuss
Default RE: MPG
Well I installed the 87 octane hypertech program last night.
It seemed to make a big difference in low end torque, except last night when it was 80 degrees outside the valves were making a lot of noise going up hills.
I think I may have the intake plenum gasket problem.
I ordered a 180 degree thermostat so maybe that will help.
When I drove to work this morning (50 degrees outside) I had no valve noise and the low end torque going up hills was better than ever and I hardly had to push the gas pedal down to maintain speed.
Old Apr 21, 2006 | 10:44 AM
  #30
Off_Road_Teacher
Default RE: MPG
Try some cooler plugs too. When I installed my hypertech, I was getting a good bit of ping going up hills. Swapped out the stock heat range plugs for some cooler ones and the problem was gone.
