paint
Old Apr 20, 2006 | 06:19 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default paint
I just drove over some wet paint and it goes all the way down the truck. Is there anything i can use to get rid of it without harming the clearcoat. I already tried the clay and it did not work.
Old Apr 20, 2006 | 10:41 AM
JustinJohnson86's Avatar
JustinJohnson86
Default RE: paint
fingernails and a lot of patience my friend, trust me, when i came home with the passenger side covered in tar, i about cried, then i busted out the dry microfiber cloth and worked on it for 4 hours...
Yeah it sucked, but with tar that was basically the only way, with paint, i'm suprised the clay didnt take it out...
Old Apr 20, 2006 | 01:18 PM
Chopper1's Avatar
Chopper1
Default RE: paint
That sucks!!!!!!!!!!!!
You could take it by a body shop and ask them. They might actually tell you what you could use.
Old Apr 20, 2006 | 02:21 PM
HuntinHanson's Avatar
HuntinHanson
Default RE: paint
did you try some rubbing compound? Make sure you wash your truck afterwards to get it all off if you do.
Old Apr 20, 2006 | 03:09 PM
Dodgeramman's Avatar
Dodgeramman
Default RE: paint
Fine Cut Buffing Compound and alot of elbow grease.
Old Apr 20, 2006 | 03:14 PM
shott8283's Avatar
shott8283
Default RE: paint
superfine 3M rubbing compound will work the best
when i was detailing i was able to practice ALOT and was really successfull with a razorblade.....but you gotta be WICKED carefull
you could also take the truck somewhere and have them buff everything out...
Old Apr 20, 2006 | 04:31 PM
Zeppelinrocks
Default RE: paint
could the rubbing compound just smear the paint instead of taking it off?
Old Apr 20, 2006 | 05:18 PM
01ramclassic's Avatar
01ramclassic
Default RE: paint
I got yellow road paint all over my truck once. I took it down to the body shop and they suggested Lacquer Thinner. I used it and it worked great but it will need to be waxed after you get done. Just get a rag and some lacquer and gently rub it. It won't hard the clearcoat but it will take the wax off. Works pretty quick too.
Old Apr 20, 2006 | 05:47 PM
Zeppelinrocks
Default RE: paint
thanks for the help im gona tre laquer thinner
