Freeze plugs
Old May 14, 2006 | 04:18 PM
pasport4x4's Avatar
pasport4x4
Default Freeze plugs
Have a 2001 Sport 4x4 with 63,00 miles on it. The freeze plugs are leaking. What am I
looking at price wise? Thanks
Old May 14, 2006 | 07:20 PM
Socha_62's Avatar
Socha_62
Default RE: Freeze plugs
I've never heard of the "freeze" plugs leaking. Are you sure its coming from there and not somewhere else and getting splashed on them?
Old Oct 31, 2006 | 05:00 AM
jcasper01's Avatar
jcasper01
well the wife has a durango and she had to get one of hers done. it was at the top and the had to tilt the moter to get to it it ran us 850.00 good luck
Old Oct 31, 2006 | 12:38 PM
Socha_62's Avatar
Socha_62
For a freeze plug?! They cost like $.65 at the parts store! Ouch [:@] I'm sure there way a way to get to it easier, to bad you had to pay that much [&:]
Old Oct 31, 2006 | 01:48 PM
steve05ram360's Avatar
steve05ram360
they can rust from the inside and under pressure, start leaking. the best thing to prevent this is proper cooling system maintanance. flush and refill with the right amount of coolant & use distilled water.
I personally have never had one fail, but know of a few others who have. every time the cooling system had gunk in it from lack of maint.
Old Oct 31, 2006 | 02:00 PM
jakebrake's Avatar
jakebrake
If your able to get to the plug, it is a pretty simple diy
Old Oct 31, 2006 | 02:24 PM
bamory's Avatar
bamory
I have to ask, what do these people do or don't do to their vehicles for all these otherwise normal functioning parts to fail. People need to follow the servicing recommended by Chrysler and sometimes go one step further as Steve said. JMO
Old Oct 31, 2006 | 02:41 PM
steve05ram360
proper maint. will prevent alot of these failures. speaking of which, my wifes '03 corolla which we just got needs to have the cooling system flushed... damn, another weekend project [&:] but hey, I dont want her stuck on the side of the road so I'll take the time to flush it, check the hoses to make sure they're not cracked or in need of replacement and refill it with some good 5 year coolant and distilled water.
Old Oct 31, 2006 | 05:22 PM
jakebrake's Avatar
jakebrake
The problem with automotive coolant is it is only good for two years unless you get the elc, then i believe it's three years. That's why I run Heavy duty truck coolant. It's good for six years, comes with anticorrosive additives. Costs more but well worth it.
