Alarm Module for Ram 2000 4x4
Old May 17, 2006 | 01:23 AM
mons_ma's Avatar
mons_ma
Default Alarm Module for Ram 2000 4x4
I have a big problem with the alarm module because is not working, and I could not foind the replacement parts, I'm living in venezuela, and here there is not a dealer that can help me.
the problem is that the engine start, but after 10 seconds turn off, because this module has the Injection controls, automatic windows, and lock door.
Some body cah tell me if can I modify this in the trck main computer and wich parameters I have to modify, or if there is another way to solve the problem
Its a Ram Truck 2500 yer 2000 4X4 5.9 Magnum
The module part number is 56045448AC.
Thanks
Old May 17, 2006 | 01:55 AM
Socha_62's Avatar
Socha_62
Default RE: Alarm Module for Ram 2000 4x4
Crap, I can't really help ya because I have a 1997, and 1998 is when they started doing alarms [&:]
Old May 17, 2006 | 03:37 PM
crazy1snow's Avatar
crazy1snow
check the crysler parts direct webpage if you can. they should have replacement modules.
Old Sep 26, 2011 | 11:08 AM
redneck_ram's Avatar
redneck_ram
yeah crazy old i know, but..... apparently my truck didnt come from the factory with the keyless entry system. will this part work on my '01 1500 so i can have keyless entry? anyone know?
Old Sep 26, 2011 | 12:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You need the Hi-line CTM Central Timer Module part # 56045448ad . Whether or not its plug and play I don't know.
Old Sep 26, 2011 | 07:36 PM
redneck_ram
zman, so this is the one i need? the part number has been replaced to this 56045448AE, and both the part number you gave me and the part number in this auction both have been given the same new part number from chrysler.
http://cgi.ebay.com/ebaymotors/2000-...item588f881ea0
Old Sep 27, 2011 | 06:47 AM
zman17's Avatar
zman17
Yea, and from my research, I'm pretty sure the dealer is going to have to set some things in it. Not to mention set the first key fob up.
Old Sep 27, 2011 | 07:00 AM
redneck_ram
Yeah dealer charges 30 bucks to program the key fobs. What else will they have to program and will i be able to drive my truck once its installed?
Old Sep 27, 2011 | 07:23 AM
zman17's Avatar
zman17
I'm not sure, but from what I read. Even when they install a direct replacement on a rig with the same one, they have to set it up.
Old Sep 29, 2011 | 01:38 PM
redneck_ram
ok, so i went to my local JY and got the module out of a 2000 sport. plugged it in and started my truck, everything worked, windows, locks, radio, directionals, and wipers.
only issue im having is: the new module is suppoed to have 2(two) plugs(a green one and a larger white one), my truck doesnt have that 2nd plug. do i have to get a new dash harness set up for the keyless entry module?
