HVAC is fubarred
Old May 22, 2006 | 11:40 PM
clutchn's Avatar
clutchn
Default HVAC is fubarred
while under above normal load(accelerating entering on-ramps, driving up hill), air coming from the vents will transfer to the defroster vents and leg vents. if i let off the gas, or maintain speed, it will go back to blowing air from the cabin vents.
ive tried cycling the dial to "max AC", "vent", and "recirculate", but it makes no difference. it will still switch on me while driving. ive watched the little plunger behind the glovebox move, while changing the settings. it seems to be doing what it needs to do. im thinking the problem is vacuum related, but there is no presence of a leak. ive also pulled out the HVAC panel, and check the vacuum line connections. all felt good and tight.
problem seemed to have occured after i put the ASP plate kit on my manifold. what do i look for now?
its a 99 ram 318/5 speed 2WD, BTW.
Old May 23, 2006 | 12:54 AM
Tani1500's Avatar
Tani1500
Default RE: HVAC is fubarred
I also have the same problem but have yet to care to go looking for the problem so if some can tell us both how to fix this. Some like hansonHVAC for instance
Old May 23, 2006 | 01:21 AM
The Burning Rom's Avatar
The Burning Rom
Vacumm leak
The truck uses vacuum to switch between the modes. It's also the purpose of the resevoir...to keep your settings from changing while you're under load/braking/etc. But if you have a leak in the system, the resevoir is useless [8D]
If the problem started after you messed around with your manifold, that's the first place I'd start looking for a leak.
Old May 23, 2006 | 02:48 AM
HuntinHanson's Avatar
HuntinHanson
the burning rom is correct. I had the same problem on my truck and it was a vacuum line that ran by the battery.
Old May 23, 2006 | 11:16 AM
DPR250R's Avatar
DPR250R
I had the same problem and this fixed mine... however I do not think you vehicle falls within range of the TSB...
http://dodgeram.info/tsb/1996/24-01-96a.htm
Old May 23, 2006 | 11:52 AM
clutchn's Avatar
clutchn
ORIGINAL: HansonHVAC
i didnt see a vacuum line near the battery. i saw a line coming off a "tee", that goes to a black plastic box inside the cowl panel.
ORIGINAL: DPR250R
that check valve is already there.
Old May 23, 2006 | 12:28 PM
shott8283's Avatar
shott8283
That "T" line that goes to a box under the cowl is your cruise control.
Old Mar 19, 2008 | 03:46 PM
clutchn's Avatar
clutchn
bump! lol
still having the problem. how do i isolate the vacuum leak?
Old Mar 19, 2008 | 07:07 PM
Mudbone25's Avatar
Mudbone25
If you cant find the leek i think theres a machine that pumps smoke throught the intake into all the vacuum lines. The smoke would leak out of any cracks. Not sure where youd get this done though.
Old Mar 24, 2008 | 07:22 PM
Joey Buentello's Avatar
Joey Buentello
replace your vacuum check valve(s)
