Lift ?'s
Old May 24, 2006 | 10:45 PM
Ramboy08's Avatar
Ramboy08
Default Lift ?'s
Does Anyone know how to get 10" of suspension lift from a kit or do you have to make it yourself the biggest i can find is a 7" from skyjacker but i want bigger. Thanks for anyhelp
Dylan
Old May 24, 2006 | 11:04 PM
Tani1500's Avatar
Tani1500
Default RE: Lift ?'s
your going to have to make it yourself. some skyjacker 7 inch V10 coils and they should give you around 9 inches. plus a spacer. your also doing to need long arms and get a re-indexing ring for the t case, plus longer shafts, also im assuming you want to run really big tires, your going to need to upgrade to a dana 60/70 front, rear and gears depending on what size tire.
Old May 24, 2006 | 11:17 PM
dirty dog's Avatar
dirty dog
there r bigger kits for our trucks there is a company that makes up to 14" suspension kits for our truck but i dont know anybody running one
the company is called full throttle its site is fullthrottlesuspension.com
Old May 24, 2006 | 11:25 PM
Tani1500's Avatar
Tani1500
yea ive heard of them too but there really expencive. just get a 7 inch sj long arm kit for the v10 / cummins and you will be fine. plus what i already mentioned of course.
Old May 24, 2006 | 11:31 PM
The Burning Rom's Avatar
The Burning Rom
ORIGINAL: Tani1500
Don't know about the suspension lift part (not into that), but I do agree with that ^^^^^^^^
Not gonna be cheap [>:]
Old May 24, 2006 | 11:54 PM
Ramboy08's Avatar
Ramboy08
Thanks Tani, that sounds like a lot of money would i have to but a complete v10 setup from skyjacker or just the coils? I really dont want to have to change axles i just want to run 38" tires. another ? for you would 5.13 gears be enough to turn the 38s or would i need to go bigger. Thank you
Dylan
Old May 25, 2006 | 12:20 AM
Tani1500's Avatar
Tani1500
depends, what trans you have? i think 4.56 or 4.88 would be fine. the hole kit would be easier. also you have to remember though with those coils its going to be a stiff ride and its not going to be the greatest flexer
Old May 25, 2006 | 12:40 AM
Ramboy08's Avatar
Ramboy08
i thought the v10 rear leaves were thicker than the 1500 leaves. i really dont want to have to spend a whole lot of money trying to get everything to fit correctly i have very shallow pockets, im not worried about flexing i just want it for mud not rocks or anything also i have a 4 speed automatic transmission would those gears still be enough srry for all the ?'s
Old May 25, 2006 | 02:53 AM
20dodgeram01's Avatar
20dodgeram01
get a 7 inch skyjacker and a 3 inch rough country suspension lift with the coil spacers.. 10 inches right there
Old May 25, 2006 | 11:43 AM
shott8283's Avatar
shott8283
I don't think anyone makes a 5.13 gear for the Corporate 9.25. I could be wrong, but I think that 4.88's are the "biggest" you can get right now.
To turn 38's 4.88's would be best, and a 7" should clear them.
