Advice on changing belt tensioner
Old May 26, 2006 | 10:35 PM
Wile C's Avatar
Wile C
Default Advice on changing belt tensioner
anyone out there done one?
I bought one to replace and my haynes manual doesn't cover how to do it. The instructions that came with it are not detailed. Just wondering if there are any caveats or anything that someone might know of and can pass along. Hoping to do it this weekend. I have changed the belt myself several times, but never the tensioner. The belt is fairly new, the tensioner is oem in my 98 (built in 97) 57k on it so that's why I believe the noise I am hearing is the tensioner.
appreciate any advice, thanks
Old May 26, 2006 | 10:50 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Advice on changing belt tensioner
No trick to it. Remove the belt. Unbolt the old one. Bolt the new one in. Put the belt back on
Just changed mine yesterday...after letting the new one sit around for a couple months [8D] I could immediately tell how worn my old one was when I went to put the belt back on [:-]
focushere's Avatar
focushere
none really pretty simple just make sure its the right tension
Old May 26, 2006 | 11:03 PM
Wile C's Avatar
Wile C
the tensioner i bought has a long threaded bolt on the back of it. there is no place on the front i can see to use to tighten it if that makes any sense. is that what yours looked like?
do i need a special tool?
thanks for the replies
Old May 26, 2006 | 11:57 PM
Sehr916's Avatar
Sehr916
Download the service manual in the merry christmas thread. For my truck I think you have to remove the ignition coil to get to the bolt int back. Hope this helps
Old May 27, 2006 | 12:37 AM
fiveliterbtr's Avatar
fiveliterbtr
On the 5.9, you need to remove the coil, then remove the 15mm nut from the "long threaded bolt" as you called it Probably the same on a 5.2, but don't know, you didn't specify an engine.
Old May 27, 2006 | 01:47 AM
The Burning Rom
Ah, the V8s are different then. Sorry [8D] I've never worked on a Magnum era 318/360 [>:] Only the good ol LA motors
Even though the directions above are correct, you should probably do as suggested and download the factory service manual from the "merry christmas"
Old May 27, 2006 | 12:56 PM
shott8283's Avatar
shott8283
Lol, I just changed mine last weekend too, after it sitting around for a few months. Anyway, yea, for the 5.9/5.2 unbolt the braket that hols the stock coil, and remove that, then on the backside of the tensioner, is that threaded bolt/rod, uses a 15MM nut, unbolt that and it will come off. After removing the braket for the coil, you can put a bolt back in to help keep the tensioner pully assy. from turning when your truying to loosen the 15MM nut.
Old May 27, 2006 | 09:08 PM
tireman_steve's Avatar
tireman_steve
very easy just changed mine to, the bolt is hidden behind the coil all 15mm nuts should only take 15min very easy
