wide tires
Old Jun 26, 2006 | 09:45 PM
ripto's Avatar
ripto
Default wide tires
What would I need to have done in order to switch from 285's (32.8 I think) to smaller (265) wide tires? What would I need to buy to have everything fit properly. Let me know if I need to supply rim and any other info, I'll check it out. I bought the truck last August and all I am aware of is the previous owner put on bigger tires, I don't know if he changed anything else down there, although the rims look stock.
Old Jun 26, 2006 | 10:21 PM
radwebster's Avatar
radwebster
Default RE: wide tires
just pop the new tires on, thats it. nothing else needs to be done
20dodgeram01's Avatar
20dodgeram01
you wouldnt need to change anything.. 285's and 265's is only about 1 and half inch diffrence and it'll fit your stock rim
Old Jun 26, 2006 | 10:23 PM
The Burning Rom's Avatar
The Burning Rom
Nothing. Just buy 265 tires.
Old Jun 26, 2006 | 11:13 PM
ripto's Avatar
ripto
awesome, thanks guys. Anyone know some tough looking wide tires? What companies should I be looking at when it comes to tires? Also, from switching to 285's to 265's with the same 3.55 gears, my gas milage should increase a bit correct? (is there anyway to check what gears you have other than looking at the sticker on the truck, mines on the underside of the hood and says something like 3.5 axle ratio, perhaps he also changed the gears but the way it performs I doubt it)
Old Jun 26, 2006 | 11:33 PM
The Burning Rom
If he changed the gears, there's no way you could know without taking the rear axle apart and counting the number of teeth on the gears.....or find out who owned the truck before you and ask him/her. I doubt he changed them for 285s.
Your mileage should go up a bit, depending on what type of tires you put on.
Old Jun 26, 2006 | 11:56 PM
ripto's Avatar
ripto
ORIGINAL: The Burning Rom
What do you mean what type of tire I put on? Like off roaders or street?
Old Jun 27, 2006 | 12:03 AM
The Burning Rom
ORIGINAL: ripto
Correct. The load range will also make a difference in mileage.
You will also get poorer mileage with NEW tires than you will get with slightly or half worn ones.
Old Jun 27, 2006 | 01:32 AM
GOD RAM IT's Avatar
GOD RAM IT
He could count drive shaft turn to wheel turn.
Old Jun 27, 2006 | 02:26 AM
The Burning Rom
ORIGINAL: GOD RAM IT
True...didn't think about that. [8D]
