is this normal?
Old Jul 12, 2006 | 10:43 AM
Aperture_Disaster's Avatar
Aperture_Disaster
Default is this normal?
Hey All,
First off this is my first post on the forum, So Hi. I am Rob I Have a 1998 dodge 2500 4x4 v10. Here is my question : When i accelerate with the A/C on the dash vents switch to the defroster vents, i am not sure if the A/C pumps stops while doing that but its kinda weird it changes vents....So... Is this normal? And if it is - is there a way around it? and if its not...what should i do?
Thanks...i've been learning a lot reading these posts.[sm=icon_cheers.gif]
Old Jul 12, 2006 | 10:51 AM
stnlycup's Avatar
stnlycup
Default RE: is this normal?
my guess is a vacuum leak....now you just have to find it
Old Jul 12, 2006 | 01:44 PM
HuntinHanson's Avatar
HuntinHanson
Yes it is a vacuum leak. The easiest way to find it is to go to autozone and rent a hand held vacuum pump. The cheapest way to find it is to start tracing the lines back looking for a crack in the line.
Old Jul 12, 2006 | 02:36 PM
The Burning Rom's Avatar
The Burning Rom
What they said ^^^^
Good luck finding the leak! They're hard to find. First thing to check would be the lines to the vacuum resevoir. And then the brake booster line.
Old Jul 12, 2006 | 09:39 PM
Aperture_Disaster
Thanks for the quick replies guys... I called a buddy of mine and he is going to help me track down the leak.
Old Jul 12, 2006 | 10:15 PM
Sinister's Avatar
Sinister
my car used to do that.. .. i never did know what it was..
btw what type of tires are on your truck?.. she looks great, and with that tread.. I definately like it.
Old Jul 12, 2006 | 11:33 PM
DODGEIT105's Avatar
DODGEIT105
On the passenger side of the engine right behind the throttle body there is a vacumm tee that is made of plastic. Many times it is there that the problems begin. Dealer part. Usually inexpensive.
Old Jul 12, 2006 | 11:59 PM
Aperture_Disaster
Hey Sinister,
they are 35 12.50 BFG A/T ko's(eagle 16.5 x 10 wheels). Its a great tire. I really like the look of the Mud Terrains(and their offroad performance).. but the A/T's are so quiet and quite agressive aswell.
Old Jul 13, 2006 | 12:00 AM
Aperture_Disaster
Dodgeit105 thanks - i will go out and have a look now.. will i be able to see or hear it?
Old Jul 13, 2006 | 03:30 PM
mojo's Avatar
mojo
It could also be the heater control valve or switch. It can also happen when you just have the heat on. My did it when I accelerated or was under a load, it would automatically switch to defrost. There was a service bulliten about it for 94 through 97 Rams. My truck was an early 98 so it had 97 stuff as well. I appologize I can't remember the SB # but if you call the service department at your local Dodge garage they should be able to tell you.
