Battery terminal post too thin.
Old Jul 12, 2006 | 03:27 PM
Silver_Dodge's Avatar
Silver_Dodge
Default Battery terminal post too thin.
One of my battery terminal posts has gotten smaller in diameter, I assume from cleaning, general use, etc. Now, when I tighten down the battery cable connection, it tightens all the way, but the cable is still loose on the post (not real loose, but I can turn it by hand when it is fully tightened). If the post were a little thicker, it would tighten down nice and tight, but it's not thick enough anymore. Is there a way to beef up the post again so that the cable can tighten on it? I hate to replace the battery, there is nothing wrong with this battery overall, and I don't really want to try another battery cable, it is also fine. The post is just not thick enough anymore. Any suggestions?
Old Jul 12, 2006 | 03:56 PM
2001ramsport's Avatar
2001ramsport
Default RE: Battery terminal post too thin.
you could cut a peice of brass or copper shim .005-.010 thk. and wrap it around the post,then put the cable on.
Old Jul 12, 2006 | 04:06 PM
theshocker's Avatar
theshocker
I know with some batteries you can replace the post. I had a die hard one time that had dual post on the + and - side that would screw out of the battery. 2001ramsport also has a pretty good idea. You wouldn't even need to wrap it arond the post , just put a small piece in between the post and the connector. You shold still get good contact.
Old Jul 12, 2006 | 04:12 PM
Silver_Dodge
Ya good idea. Thanks, i'll try that.
Old Jul 12, 2006 | 04:32 PM
Tani1500's Avatar
Tani1500
you check to, that might be covered under warrenty if you have one.
Old Jul 12, 2006 | 04:34 PM
Silver_Dodge
Warranty on my truck or on the battery? I know I don't have one on the truck anymore. I doubt i ever had one on the battery.
Old Jul 12, 2006 | 08:06 PM
crazy1snow's Avatar
crazy1snow
i'm going with the shim on that one. just wrap a piece of sheet metal there and you'll be fine. just make sure it's not aluminum.
Old Jul 12, 2006 | 08:19 PM
RJlovesbeer's Avatar
RJlovesbeer
yeah i would try the copper shim...i know you can buy small sheets (more like pieces) at ace hardware...im sure any hardware store will sell it.
Old Jul 12, 2006 | 08:33 PM
Silver_Dodge
How about using a penny? But, a guy on another forum told me that any shim not made of stainless, or lead, will set up a galvanic condition & cause corrosion.
Old Jul 12, 2006 | 11:52 PM
fiveliterbtr's Avatar
fiveliterbtr
ORIGINAL: Silver_Dodge
Correct, dissimilar metals will corrode, and rapidly...stainless or lead.
Is the cable end all of the way down on the post? I've (carefully) taken a socket that's just larger than the post and tap the end down a little bit...never cracked a battery, and they've tightened right up. Definately not something I learned in school tho
