Cruise Control INOP
Old Jul 20, 2006 | 06:46 PM
pipedreams's Avatar
pipedreams
Default Cruise Control INOP
My cruise control stopped working. Everything "looks" like it's on and engaged when it comes to the lights etc on the wheel...it just doesn't work. I know there's probably a hundred things that could cause this, so right now I'm just looking for the most obvious places to start trouble shooting. So far all I can say is thokat I don't see anything broken or disconnected and it doesn't seem to be electrical as stated.
Old Jul 20, 2006 | 07:22 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Cruise Control INOP
Vacuum leak would be my first thought. Typical vacuum leaks occur in the lines for the 4wd system (between the transfer case and front axle). Another typical break is in the lines to the charcoal canister.
The vacuum reservoir line is another good one to check.
Old Jul 20, 2006 | 07:30 PM
pipedreams's Avatar
pipedreams
Okay...........sounds like a good place to start. thanks!
Old Jul 20, 2006 | 08:34 PM
kyleitzen's Avatar
kyleitzen
mine did the Exact same thing.. a few people around here had that same prob it was the line that runs behind the drivers side headlamp in the area of where the fender meets the radiator support
Old Jul 20, 2006 | 08:38 PM
pipedreams's Avatar
pipedreams
A vacuum line?
