low end knock
Old Jul 21, 2006 | 02:05 AM
tireman_steve's Avatar
tireman_steve
Default low end knock
well this is what i got I have a 99 Doge ram 4x4, 5.2 with 66k every time it cools down or i start it up in the morning i can hear an engine knock it goes away in about 10mins or when the oil warms up. it seems to come from the back of the motor by the distributar and down the edge where it bolts up to the tranny. i cant pin point the sound but i can hear it in the oil pan and up the back of the motor and also down by the base of the distributer. i cannot hear in in the block(im usuing a stethascope) it is very loud but almost goes away when the motor warms. i have tried different viscosity oils and lucas,mmo, and they dont seem to help one bit, thicker oil seems to make it a little worse, everyone says its low end and that where it sounds like. they say its a bad motor but im not convinced. i would love it for someone to help it would be greatly appricated
Old Jul 21, 2006 | 02:55 AM
ChaoticBastard's Avatar
ChaoticBastard
Default RE: low end knock
Flywheel, Torque converter bolts??wouldnt make much sense that it would go away after 10 mins if it was that.But worth a check.I would say if your oil pressure has ever been low,You most likely have internal damage and start looking for a new engine.Or a rebuild.
