Holley throttle body
Old Aug 5, 2006 | 07:14 PM
steve05ram360's Avatar
steve05ram360
Default RE: Holley throttle body
with a bigger cam, obd1, you wont have any learning going on. your next best bets are to open up the intake, cut the runners down and open up the injector bores, then clean up the tb opening some, there's a lip there. and get the heavy duty heads or the r/t's. your motor will really wake up at that point because those two items are your next bottle neck.
plus, one other thing is you can get a larger air filter. I went with a 6x8 round K&N and it made a nice difference in the upper end performance.
Old Aug 6, 2006 | 12:31 AM
karkrazy's Avatar
karkrazy
I not going to do anymore to the actual engine ( heads, porting, intake) until I rebuild it. Then I'm getting Edelbrock heads, bored .60 over with forged internals and mopar manifold. But thats a long way off. I might add a MSD 6AL and lower the gears from 3.55 to 3.90. I've got the 67 dodge dart to make into a true street terror( can you say a nitrous feed 402 stroker). This is just something to play around with in my spare time. Hey, Steve00ram360 you're on dodgetalk and a few other forums too aint't you? I believe we've messaged each other before.
