Leak from black cable under passender door
Old Aug 6, 2006 | 02:10 PM
ripto's Avatar
ripto
Default Leak from black cable under passender door
I'm not familiar with much underneath the truck but I did notice this morning a little puddle about 3in in diameter underneath my truck about 5 inches in from the passenger side of the truck. It looks like a black plastic cable about 1in in diameter with a square shaped plastic piece (maybe a mount?) thats kinda loose. The liquid drops down from the cable down a piece of metal about 4 or 5 inches long, so its a noticable leak. Doesn't smell like anything, looks to be clear, anyone know what this might be? Also, I did go offroading a little bit through some grass and small bushes, maybe something hit it somehow, this is the first time I'm noticing it, not sure if its been there before but I don't think it has. Sorry I'm not so technical. I will get pictures of this up tomorrow.
Old Aug 6, 2006 | 02:43 PM
Racinfan83's Avatar
Racinfan83
Default RE: Leak from black cable under passender door
I imagine it is the condensation off of the AC condenser. Mine still has a puddle under it in the morning after sitting overnight....
Old Aug 6, 2006 | 03:32 PM
fiveliterbtr's Avatar
fiveliterbtr
Yup, sounds like A/C evaporator draining normal condensation...the only fluid that is totally clear is brake fluid when it's brand new, but your description sounds like a/c drain.
Old Aug 6, 2006 | 04:49 PM
ripto's Avatar
ripto
alright, so its nothing to worry about then?
Old Aug 6, 2006 | 07:59 PM
Sehr916's Avatar
Sehr916
Are you talking about this?
I had a "leak" from this but was told it was just condensation
Old Aug 6, 2006 | 09:43 PM
ripto's Avatar
ripto
no doesnt look like that, I'll post a picture tomorrow when I have access to a digital camera
Old Aug 7, 2006 | 03:29 AM
radwebster's Avatar
radwebster
easy way to check...next time your truck is running, with the A/C on, get out and watch under the truck for a minute, you will see the water/condensation dripping out slowly. perfectly normal
Old Aug 9, 2006 | 02:23 AM
ripto's Avatar
ripto
here is a picture of the hose/cable I am talking about which seems to be related to the AC. Its the black one above the 099 sticker.
[IMG]local://upfiles/21486/C0CE33FAC0F44A65A157661CABE04822.jpg[/IMG]
Old Aug 13, 2006 | 06:57 PM
ripto's Avatar
ripto
ORIGINAL: Racinfan83
Is this the cable?
Old Aug 13, 2006 | 08:02 PM
fiveliterbtr
That "cable" looks like the vacuum lines going to the vapor canister (emissions crap)...if you were to follow it from that picture, towards the right (front), you'll end up running into the evaporator drain, probably just dripping onto it and running down the line.
