Just finished installing my leveling kit
I had the rough country 2 inch leveling kit I just put on the Ram. I purchased the polyurathane one because it should hold up a little better in these michigan winters. still only have my 265/75R16 on right now. Need some new ones. looking to go some where from 285/75R16 up to 35x12.50R18 or so. anything inbetween will work too. im just a broke college kid, so if anyone wants to help out, let me know.
Anyway, total install time was 2 hours 45 minutes. luckily weather was nice. pictures show before and after, decent pics, but it looks better up close in person. I kept my stock shocks, it was a really simple install.
apparently my pics are too large to for this site, so just check out my site at cardomain, there are the before and afters as best i could do...enjoy!
http://www.cardomain.com/ride/737627/1
ok, here are the pictures, got them all fixed up...or you can just check out the link
[IMG]local://upfiles/37884/E68910FCAA4C4B2EA8D178E2F95724F5.jpg[/IMG]
[IMG]local://upfiles/37884/DAD46285A9634AFEBA152C17F823EA25.jpg[/IMG]
[IMG]local://upfiles/37884/7AE81CB6B78A41C2A64A743A35CB447D.jpg[/IMG]
[IMG]local://upfiles/37884/8F32E21EB4E441C187CB4EDF45C575B4.jpg[/IMG]
yea, looks pretty close, the rear may still be a bit higher, but not by much. I think its a much better stance it has, now i all need is some rubber!
heres a few tips for you.
-shoot all the nuts and bolts with some lube before to make it a little easier.
-be sure to use lock tite on all new hardware intsalled
-do the drivers side last, its harder, so once you got it down on the passanger, it will go much smoother
-disconnect the front sway bar from both sides otherwise you will never get that spring and space in there.
-put the spring spacer in top first, then bottom last (much easier, just kick into place)
-a second set of hands just to help hold the spring and spacer when puttin that in is a ton of help cuz its really heavy.
if you have any specific questions, go ahead and ask....ill help with what i can
Trending Topics
Check out my cardomain page for the leveling kit install with pics!!!
http://www.cardomain.com/ride/259005/9
Hopefully that will help some
- jared
- jared
