bad low end
Old Aug 14, 2006 | 04:38 PM
codyc_13's Avatar
codyc_13
Default bad low end
have a 2001 dodge ram 1500 with a 5.2 L engine and i have extremely bad low end power. it has 54,000 miles and i just changed the plugs, wires, cap and that stuff did not help at all. i took it to the race track and it ran a 18.36 i have a friend with the same exact truck but has a 3.9 l v6 and it will outrun mine something is not fight does anyone know what the problem is or what to do to fix it
Old Aug 14, 2006 | 04:46 PM
steve05ram360's Avatar
steve05ram360
Default RE: bad low end
check for a plugged cat, that will definately slow you down. another issue is the pcm may have been flashed with a program we call the death flash... it kills all your power in an attempt to stop pinging. an aftermarket programmer will fix it.
Old Aug 14, 2006 | 05:51 PM
20dodgeram01's Avatar
20dodgeram01
i have the same truck as you except a 5 speed.. that programmer really does help it out a lot.. pretty much a night and day diffrence.. also get a low temp stat and a k& n drop in filter.. i can keep up with 5.9's and also beat 1500 ram offroads that are also 5.2's.. except they have 4.10s and i still have 3.55's
Old Aug 15, 2006 | 12:15 AM
Dlinzy's Avatar
Dlinzy
Make sure you installed the correct plugs and they're all gapped correctly.
And spending a lot of dough on those Platinum Bosch is a waste of money.
Stick with the Champions and be happy again.
I know i learned the hard way, dam Bosch S+4 Platinum CRAP.
D
Old Aug 15, 2006 | 12:32 AM
Sinister's Avatar
Sinister
what is your gearing set at?
