No Heat
Old Sep 2, 2006 | 04:26 PM
Vince96's Avatar
Vince96
Default No Heat
I have no heat in my 96 RAM. It has great AC but no heat. I was told to check my thermostat and I replaced it with no change. Could my heater coil be clogged or maybe its just a switch malfunction?
Old Sep 2, 2006 | 04:48 PM
Vince96's Avatar
Vince96
Default RE: No Heat
Sorry guys, did not previous Q&A earlier in this area here...I will get the core flushed and see what happens. Mods you can delete this question.
Old Sep 2, 2006 | 10:11 PM
M.SHANK's Avatar
M.SHANK
Default RE: No Heat
I have a 2000 1500 and I have heat but my truck takes a long time to get warm. Is this normal for Dodge trucks? I also have a 94 Dakota that never really gets warm enough for the heater to work well either.
Old Sep 2, 2006 | 10:45 PM
DieselDemon's Avatar
DieselDemon
Default RE: No Heat
Long time to get heat is usually a thermostat that is stuck open. And always make sure the coolant is in good condition and at the proper level.
Good luck.
Old Sep 2, 2006 | 11:50 PM
M.SHANK's Avatar
M.SHANK
Default RE: No Heat
I put a new thermostat in the dakota, new coolant and flushed out the heater core. The temp gauge barely even registers heat even in the summer. Its a mystery to me but my 1500 Ram atleast gets a little over 130 degrees. Guess wich one I am gonna drive in the winter? lol
Old Sep 3, 2006 | 12:18 AM
DieselDemon
Default RE: No Heat
I'd say you were sold a bum thermostat. It happens. I am not super familiar with the Dakotas but make sure the thermostat does not need to be mounted a certain way. If your stat mounts sideways, you usually have to have the little breather at the top. If not, it is possible to keep an air bubble trapped in their for a long, long time. There's not too many choices of what could be wrong. Double check the operating temp for the stat as well.
Good luck.
