will 285/75/16s fit
Old Sep 10, 2006 | 07:37 PM
banshee350's Avatar
banshee350
Default will 285/75/16s fit
I have a 1999 ext cab 4x4 Ram with the stock 16 inch 5 spoke mags, I would like to know if 285s will fit.. I am pretty sure they will.. I just wanted to make sure before i purchase them
Old Sep 10, 2006 | 08:36 PM
MGDMike's Avatar
MGDMike
Default RE: will 285/75/16s fit
Sure.
Old Sep 10, 2006 | 09:14 PM
Ramdamit98's Avatar
Ramdamit98
They should fit fine without rubbing on the stock rims. Aftermarket rims with the 285's may rub a little.
Old Sep 10, 2006 | 11:07 PM
Sinister's Avatar
Sinister
yes, they fit. i run 285s, full wheel lock will end up rubbing, adjust your steering stop bolts.
Old Sep 11, 2006 | 12:55 AM
dsertdog56's Avatar
dsertdog56
In the day this was one of the top 5 questions asked...and yes they'll fit, it appears different trucks rub a little, or not at all.
My truck's had 285's on it since I bought it...and with or without a lift, I've never had an issue with clearance.
Old Sep 11, 2006 | 01:26 AM
mdewitt71's Avatar
mdewitt71
I think you will be good with the stock rims but they are only 7 inches wide on most Dodge Rams (kind of skinny for that tire).
In my experience, it depends on the tires actual size........I mean some 285s are actually taller and a bit wider than some brands. I I have seen some rub just slightly at full lock and others that rub a lil more.
For example I am putting on 285 Buckshot mudders which actual measurements are a hair over 33 inches where BFGs and Pro Comps were a lil under 33 inches (usually around 32.8").
Old Sep 11, 2006 | 05:28 AM
habeba86's Avatar
habeba86
ORIGINAL: mdewitt71
My firestone are like 33.1" You will rub a little, but as said its jst when fully turned.
Old Sep 11, 2006 | 11:15 AM
Tommygunz's Avatar
Tommygunz
285/75/16 pro comp Xterrains, no rubbage, even under heavy articulation.
Old Sep 11, 2006 | 03:23 PM
Sinister's Avatar
Sinister
i suppose the tread has alot to do with rubbing as well, the meatier the tread the more chances of rubbing.
Old Sep 11, 2006 | 04:42 PM
Ramdamit98's Avatar
Ramdamit98
If you go on the tire rack website they give you the actual size of a lot of tires including the number of rotations per mile for each tire. I was surprised a little on the amount of difference on tires of the same size but different brands nad models.
