Brake pedal goes to the floor
Old Feb 7, 2007 | 01:54 PM
TMS Bill's Avatar
TMS Bill
Default RE: Brake pedal goes to the floor
The bleeder nipples are located on the back side of the wheel cylinders (rear) and the calipers (front).
Old Jun 21, 2007 | 06:41 PM
jdphrivera's Avatar
jdphrivera
another dumb question if i change just the pads do i need to bleed the brakes from rear right clockwise to front right? 2005 durango!
Old Jul 16, 2022 | 07:54 PM
michael beez's Avatar
michael beez
Originally Posted by tuckerke
I have a 2000 Dodge RAM 1500 4x4
I have replaced both front rotors,calipers, brakes, both rear cylinders and brakes and also the brake line that supplies fluid to the back brakes. I have bled all the brake cylinders from rear to front and everytime I start the engine and the power assist kicks in the brakes go to the floor.
Is there something that I am missing or omitted from the bleeding process?
this is for all you dumb asses in these. stupid *** forums, that you can never get answered correctly. And I only say this cuz we just went through it, you must make sure the bleeder valve is at the top of the caliper it cannot be on the bottom or else it will not bleed.
Old Jul 16, 2022 | 08:35 PM
And you just had to resurrect a 15 year old thread to post this? You do realize, that there are a number of threads, some as recent as the last couple months, where just this topic was covered, and for the same reason......
Old Jul 17, 2022 | 09:00 AM
Moparite's Avatar
Moparite
Looks like there is more that one "dumb ***" here!
