how much for some gears?
Old Sep 21, 2006 | 03:34 AM
pollocksn's Avatar
pollocksn
Default RE: how much for some gears?
So should the gear ratio be stamped on the diff?
Old Sep 21, 2006 | 03:35 AM
The Burning Rom's Avatar
The Burning Rom
To answer a few questions in this thread...
Typical price for gears + install is between $400 and $500 an axle.
Dodge has an assembly plant in Mexico that builds trucks for the American market. They've had one there for decades
4:10s were standard in Off-road package Rams. Optional on everything else.
Rear discs were on the 01 1/2 tons and 01 & 02 3/4 ton and 1-ton trucks. Stick with the drums and upgrade the wheel cylinders...much cheaper
You will notice a performance loss going from 285s to 35s without re-gearing. Not so much on the highway, but definitely from a stop.
Last but not least, rear axles are all the same....doesn't matter if it's 2x4 or 4x4
Old Sep 21, 2006 | 03:53 AM
pollocksn's Avatar
pollocksn
Well burning rom swooping in like a screaming eagle and answering some questions, thanks. I try every night to go to sleep knowing more than i did when i woke up. I can now say that I have accomplished that at 11:53pm.
Old Sep 21, 2006 | 05:14 AM
shott8283's Avatar
shott8283
ORIGINAL: The Burning Rom
that would explain why my buddies 01 sport non offroad has stamped 4.10 diffs...
and as far as i know there were absolutly no 1/2 tons with disc brakes.. they made the switch to rear discs in 01 and 02 with the 3/4 and 1 ton trucks.. but no 1/2 tons came off the factory line with disc brakes.. mines a 01 and it had drums, and everyone else i know on here with 01's and other forums with 01's have drums..
to be exact.. 2001.5: All 2500, 3500 Four wheel Disc Brake - built after Jan 1, 2001
pulled right off of http://www.dodgeram.org/tech/specs/brakespecs.htm
Old Sep 21, 2006 | 07:13 AM
Chopper1's Avatar
Chopper1
http://www.drivetrainspecialists.com/categories/chry/
