Control Arms Inter-changeable?
Old Sep 25, 2006 | 12:48 PM
DPR250R's Avatar
DPR250R
Default Control Arms Inter-changeable?
Can you use control arms from a 3500 on a 1500?
Itlooks as though the bushings are the same... not sure about the OEM arms though...
Old Sep 25, 2006 | 11:36 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: Control Arms Inter-changeable?
No. According to the parts book they are different.
The arms from a 7500lb GVWR 2500 are the same, but not the ones from an 8800lb GVWR 2500.
Old Sep 25, 2006 | 11:54 PM
DPR250R's Avatar
DPR250R
Hmmm... OK... Thanx Rom...
Old Sep 26, 2006 | 01:24 AM
20dodgeram01's Avatar
20dodgeram01
are 2500 control arms longer? or maybe control arms off a offroad model? that would really help to center my axle back up after that 3 inch suspension lift
Old Sep 26, 2006 | 01:25 AM
shott8283's Avatar
shott8283
r u looking for added length to correct an axle-pull-back? or just stronger/beefier
Old Sep 26, 2006 | 01:29 AM
20dodgeram01
axle pull-back.. i have 35x12.5's on 15x10 wheels.. the 3 inch suspension lift pulled the axle back some causing it to really rub the body.. im hoping longer control arms will help center the axle back up giving me more room
Old Sep 26, 2006 | 01:40 AM
shott8283's Avatar
shott8283
that was wierd.. you and i posted at the same time.. i was asking the fella that started the thread lol. anyway.. the offroad rams have the same length control arms as the regular 4X4's do.. i think TGC and DT profab make control arm replacements for the stock location and are 1/2" added in length to help combat axle-pull-back.. either way.. adjustables with heims would be better.. you can dial on your caster and center your axle where you want it.. given you have enough room in the adjusters to do so.. you could go long arm kit but with only 3 inch lift ,, you might bind since the travel is much more limited and less then a larger 6 inch type lift.. you could fab up yourself a set of "long arms" and have them just a bit longer then the stockers.. LA can give you a better ride because instead of hitting a bump and the force traveling aft through the stock control arms and into the frame and THEN letting the axle go up in suspension .. the LA's allow the axle to flex first.. kinda like a leverage thing if you think about it.. its a give and take with after market control arms..
Old Sep 26, 2006 | 01:45 AM
20dodgeram01
hmm.. yea i looked at a set of adjustables off TGC but they were 389 bucks! i dont plan on going any bigger then a 3 inch suspension and 3 inch body.. also my tires are out of alignment right now. they are leaning outward so maybe if i get my front end re-aligned it'll help pull the axle back forward maybe?? i wonder why the offroad rams have the same length control arms with a factory 2 inch lift.. i guess 2 inches doesnt make that much of a diffrence at all in throwing your axle off center
Old Sep 26, 2006 | 02:40 AM
shott8283's Avatar
shott8283
yea.. the 2" springs are the "max" before the axle starts to come back.. i added my 2 " TGC spacers and yanked my axle back something feirce.. lol.. ya the TGC and DT arms are friggen expensive..thast why i siad fabbin up yourself a set willl prolly cost you less if you ahve the tools to do it (welder )
when you get the alighnment done ask them to max out the caster.. maybe adjusting the adjuster-lobes on the stock control arms might send it forward a smidge and save ya a little.. not sure if it will work b/c the lower CA might keep it in place and just tilt the axle.. ( i think its the upper that has the lobe.. trying to picture it now ) couldnt hurt to try
i might try..i just thought of it
Old Sep 26, 2006 | 04:32 PM
DPR250R's Avatar
DPR250R
ORIGINAL: shott8283
My bushings are shot on my control arms(cracking and old). If i can I would like to replace the conplete control arm setup with a stronger one.
I do not have a lift and do not intend to ever lift my truck.
Do they make aftermarket arms that take place of the stock arms with bushings installed?
I have access to a shop... so i was thinking of buying a set of used arms welding plates on the bottom of them and swapping the bushings out. I want to have them ready so i can spend one day swapping them out. This is my daily driver...
