Tranny Bolt Torque Spec?
Old Oct 2, 2006 | 11:59 PM
TexasEd's Avatar
TexasEd
Default Tranny Bolt Torque Spec?
Hello to all from a newbie. I recently purchased a 2001 Ram 1500 5.2 and plan to change the tranny fluid and filter. Would like to know the bolt torque spec for this truck? Also would like to know if the dual exhaust was standard from the factory for this truck?
The previous owner installed Flowmasters but was not sure if the duals exhaust was stock? Thanks in advance for your comments.
Old Oct 3, 2006 | 12:10 AM
dodgerules86's Avatar
dodgerules86
Default RE: Tranny Bolt Torque Spec?
Welcome to DF.
The transmission pan bolts get 13ft lbs. Note: when selecting transmission fluid, make sure you use ONLY ATF+4 fluid.
The dual-exhaust was not from the factory.
Old Oct 3, 2006 | 12:17 AM
TexasEd's Avatar
TexasEd
Thanks very much for the quick reply. I'm glad to know that I got a bonus in buying the truck with the dual Flowmasters. The truck really sounds nice. I noticed the previous owner also installed the K&N air filter. I'm curious if he also installed an aftermarket chip?
Thanks again from TexasEd!
Old Oct 3, 2006 | 04:52 AM
silverram99's Avatar
silverram99
If it is a chip look at your PCM on the passanger side of the engine compartment. It will be a silver box with 3 connectors plugged into it. The middle one will have a box on it that will probably say JET or something on it if it does have a chip. It might have a programmer loaded to it though and the only way to tell that is if you have the programmer. Welcome to Dodge Forum
Old Oct 3, 2006 | 12:50 PM
Socha_62's Avatar
Socha_62
Since your going to be looking at the PCM anyways, see if it has the "Death Flash" since I doubt you have anything but stock PCM. (If it had a Mopar Performance PCM in there that'd be a sweet deal too though )
There should be a sticker on the PCM that says something similar but not exact to "Authorized Flash" or Authorized Reprogram". Pretty much if it says anything about an Authorized change to the program. The Death Flash retards timing, zapping HP. If you have it get a Hypertech Programmer or a Mopar Performance PCM to fix it!
Old Sep 9, 2017 | 09:14 PM
terrieharjo's Avatar
terrieharjo
Default Transmission
Serial number PK5211842626624152. Need torque specs for this transmission dodge ram. Front and rear adjustment band bolts
Last edited by terrieharjo; Sep 9, 2017 at 09:24 PM. Reason: Front band adjustment bolts and rear
Old Sep 9, 2017 | 09:21 PM
Which bolts?
