Rod bearings ?
Old Aug 28, 2017 | 12:18 AM
getdown78's Avatar
getdown78
Default Rod bearings ?
i bought a used 5.9 over 1 yr ago and now got the chance to tear it apart to re gasket it and check bearings and found the rod bearings have wear but the truck had 240,000 miles on it ! I need to know if they are standard ? Number on them are DA-49 ! Mains looked good but might replace them while i am there !
Old Aug 28, 2017 | 08:11 AM
With that many miles on it, I would just replace them.
Mic out the rod journals, that should tell you what size bearings you need.
Old Aug 28, 2017 | 11:36 PM
getdown78's Avatar
getdown78
Thats the plan but i need to know if they are standard ?
Old Aug 29, 2017 | 11:46 AM
That's why you measure the journals, and see what size they are.
Old Sep 5, 2017 | 09:45 PM
getdown78's Avatar
getdown78
So what is the rod journal suppose to be ? I need a size to compare to /
Old Sep 5, 2017 | 09:54 PM
2.125 for a 5.9.
Old Sep 9, 2017 | 04:29 PM
getdown78's Avatar
getdown78
so for 240,000 miles is it normal for the upper rod bearings to wear to copper ?
Old Sep 9, 2017 | 09:22 PM
Yes. That's normal. The babbit is only a few thousandths thick.
