squeek
Old Oct 3, 2006 | 12:01 AM
nugo's Avatar
nugo
Default squeek
ok, im getting a pulsing squeek from my front driverside break area. i replaced the rotors and pads, neverseazed the back of the pads and the caliper contacts. would it possibly be the caliper bolts or sleaves being worn? not to sure what to check next. could be wheel bearings. i dont know. but im tired of dumping money into it and not getting results. so, any info would be appreciated.
thanks
nugo
Old Oct 3, 2006 | 04:33 AM
silverram99's Avatar
silverram99
Default RE: squeek
I would look into replacing the caliper slides on both sides. The kits are like 12 bucks at AutoZone. I really doubt that it is a wheel bearing because that is usually a grinding noise. Maybe someone else has a suggestion.
Old Oct 3, 2006 | 04:01 PM
Racinfan83's Avatar
Racinfan83
Default RE: squeek
Are you sure it is from the brakes? I had a maddening squeak for a long time in that area of the truck and it turned out to be the shifter linkage or the steering shaft joint. I spray-lubed both and the squeak went away......
Old Oct 3, 2006 | 04:12 PM
silverram99
Default RE: squeek
I don't want to jack this thread but Racinfan where are you from in Missouri? I'm in Pittsburg, KS about 5 miles from the MO/KS state line. Just wondered if there we any DF guys close by.
Old Oct 3, 2006 | 05:24 PM
Dodge4x4810's Avatar
Dodge4x4810
Default RE: squeek
Does this only happen when you apply the brakes and are you sure that the brakes are what causing it? Because if it happens all the time, driving down the road, it could be ball joints, they will cause a creeking noise, at slow speeds you can hear it and the creeks will speed up and be harder to hear when you speed up.
Old Oct 3, 2006 | 05:45 PM
Wilks's Avatar
Wilks
Default RE: squeek
Dose it quit when you apply the brakes?
Old Oct 3, 2006 | 05:50 PM
Wilks's Avatar
Wilks
Default RE: squeek
I've had the same problem in the past. Get some of the orange anti-squeek made for brakes.
Old Oct 3, 2006 | 05:55 PM
nugo's Avatar
nugo
Default RE: squeek
it quiets down but dont stop when i brake
Old Oct 3, 2006 | 06:00 PM
nugo's Avatar
nugo
Default RE: squeek
ok well im gonna go get some new sleaves and some silicone spray for all the joints in the front end, thanks for your replys guys.
Old Oct 3, 2006 | 09:15 PM
nugo's Avatar
nugo
Default RE: squeek
well that didnt help a thing. any more suggestions?
