2000 v8 5.9 dodge ram help
RE: 2000 v8 5.9 dodge ram help
P0720 - Low Output SPD Sensor RPM, Above 15 MPH, which means: (a) The relationship between the Output Shaft Speed Sensor and vehicle speed is not within acceptable limits, or (b) Output shaft speed is less than 60 rpm with vehicle speed above 15 mph (4-speed auto. trans. only).
P1281 - Engine is Cold Too Long; which means: Engine coolant temperature remains below normal operating temperatures during vehicle travel (Thermostat).
For P1281, as it says, thermostat, or maybe the engine coolant temperature sensor.
For P0720, maybe a bad speed sensor?
The temperature will cause you problems, because your truck will keep dumping fuel into the engine to compensate for how cold it "thinks" the motor is. I would definently look into that one. The other may not be such a big deal until your ABS or something doesn't work. The speed sensors aren't that expensive anyway.
ORIGINAL: dodgerules86
I just talked to oriely's and they cant find a coolant sensor might this be called somthingd else?
thanks again for all the help
Trending Topics
If you haven't found it yet here's a service manual for an '01, but it should cover you pretty good for your 2000. It's a pretty big file so if your on dial-up it'll take a while.
http://www.neonix.org/nero/files/2001ramsrvcmanual.zip
Hopefully this will help you a little.
